change injector o rings on 03all monte now getting p0205/p0300 code. help
Got everything squared away. Luckily it was just as i had thought, the injector wiring clip had came off the injector. During my first fix when i had swapped out all the injectors O rings, i had assembled all the motor components when i realized the i had gotten the temperature sensor wiring stuck towards the back of the motor near the fire wall. I quickly disasembled half the top intake enough to pull the temp sensor wiring back towards the front of the motor in order to properly clip it in place. While doing so as i tugged on the temp sensor wiring i pulled Cylinder #5 injector wiring as well thus disconnecting. So glad it ended up being a disconnected injector rather than a bad injector.
Thanks everyone for your help.
silver86
09-04-2010 11:45 PM
nitehawkjcb
04-13-2010 11:49 PM
