6th Gen ('00-'05): 2002 Monte Carlo SS oil level sensor replacement
Old 06-23-2014, 11:01 AM
Huckster's Avatar
Default 2002 Monte Carlo SS oil level sensor replacement
Just wondering if anybody has ever replaced your OIL LEVEL SENSOR? Located on front of oil pan. Mine is leaking a small amount on ground. Can this be done fairly easy? Do you need to remove oil pan? No "You Tube" videos on that. Just the oil pressure sensor. I have seen the part on line for about $54.00.
Old 06-23-2014, 01:29 PM
are you getting any type of code telling you the sensor is bad? if not, it could just need to be tightened or taken out and cleaned and reinstalled.
but if you need one, go to the junk yard to get one. they are super easy and in most cases free.99.
also, ref #8 on the pic below. it is super easy to replace and should only take 1min to do.
Old 06-24-2014, 06:56 AM
Huckster's Avatar
Default Low oil sensor leaks
No warning light, but I degreased the lower end of engine to locate my oil drip and noticed just below the sensor was wet with some oil. Didn't want to tighten because it was plastic. But now I will give it just a little turn with wrench. Must be screwed into oil pan.
Thanks
Old 06-24-2014, 10:12 AM
Thanks
yes, it is screwed into the oil pan. it is probably very very brittle, so be careful not to break it.
i would just go to the junk yard and grab a couple personally and swap it out.
Old 06-24-2014, 07:26 PM
owens91's Avatar
ive done this before and its faily easy just have a pan ready and an open ended wrench and BOOM! problem solved
Old 07-02-2014, 08:27 PM
Huckster's Avatar
Default Oil sensor leak
You were correct!
Did this and sure enough, no more leaks!
Thanks
Old 10-18-2015, 02:00 PM
Same procedure for an 07 ss? Have that message coming on. Oil level from stick looks good. Oil life was reset and still getting that check oil level message. Sensor?
Old 11-15-2018, 06:49 PM
Default 2001 Monte Carlo SS- Oil Lever Sensor- leaking from the connector
Hi all, My 2001 Monte SS is leaking in between the oil lever sensor and the connector where it plugs into the sensor.
Wise to get just a new connector? Thanks!
Pam
Old 11-15-2018, 06:56 PM
Odds are you just need to replace the oil level sensor. I've had oil pressure senders fail and spray oil all over and in the connector, never even cleaned the oil off (but they do make cleaners you could spray on if you wanted), plugged it in and all good.
S.O.G.
10-21-2015 11:22 AM
Hiroska
07-02-2013 10:55 AM
01MoneyCarloSS
08-02-2012 05:13 PM
brando1083
11-15-2007 10:12 PM
dogmanx
06-29-2007 08:02 AM
Quick Reply: 6th Gen ('00-'05): 2002 Monte Carlo SS oil level sensor replacement
