6th Gen ('00-'05): 2000 Monte Carlo SS - In Need of Transmission. Interchange Guidance?
Old Apr 26, 2012 | 02:17 PM
monte07's Avatar
thats wiered i thought the trans from the 6th gen and 7th gen share the same trans i didnt know that there are some subtle differences to the same trans? talk about a stumper i wonder what is the defferences are?
Old Apr 26, 2012 | 02:27 PM
I'm pretty sure it is just something electrical and your PCM won't know about it and it could affect something.
Old Jun 6, 2013 | 08:07 PM
robknight13607's Avatar
I ran into this a couple months ago with my Monte. Got a trans from a 2000 Impala and then started getting a code for wrong gear ratio. Had it scanned, said the trans came out of a mini van. Go figure.
Old Jun 7, 2013 | 04:03 AM
whitemonte's Avatar
13 month old thread gets necro'd, lands in my email inbox, brings me back..
My poor monte is sitting outside, under a car cover ,retired, until I can buy a new tranny and engine for it. This tranny in it now is about done. The engine has random misfires in all cylinders and after changing out the coils, ICM, plugs and wires, as well as doing a compression test, I cannot find the problem.
Old Jun 7, 2013 | 05:29 AM
Check fueling for the misfires. Fuel filter, fuel pump, etc.
Old Jun 8, 2013 | 04:55 AM
whitemonte's Avatar
VERY interesting.
I don't recall if it started after I did it or not, but I had to repair a fuel line and changed the filter in the process. I know I am not losing gas from the seams where I replaced the (vinyl?) line, but maybe the filter is bad? That's a good suggestion, Chibi, and I'll check it out whenever I decide to go ahead and dig into the monte.
Old Aug 9, 2017 | 11:14 PM
Monte metcalf's Avatar
So I bought a pull a part 02 Ls Monte for the trans and I want to put it in a 06 Ls will I be able to do this and if so what may need modified ???
pitchforksparky480
May 9, 2015 08:43 PM
highdefinition223
Feb 15, 2015 07:04 PM
Paul Kizer
Feb 14, 2015 01:33 PM
bigmyyke
Apr 14, 2014 11:11 AM
06MCSS
Dec 18, 2009 09:59 PM
