transmission interchange info
Old Feb 13, 2015 | 07:14 AM
highdefinition223's Avatar
Default transmission interchange info
I have a 2001 ss with a bad trans. What model and years would be a direct swap i plan on putting a l67 from my Riviera in it. I know the riv has different mounting locations for the trans so it wont work. Since i want to go with a hd unit would the axles from the same donor car for the trans work. Not really concerned with final gear ratio ill be getting a tuned pcm from zzp.
Old Feb 15, 2015 | 03:14 AM
l67ss's Avatar
What year riviera?
Old Feb 15, 2015 | 06:33 AM
owens91's Avatar
There's a tag on your transmission if you look for it near the driver axles you would see it. I'd say look around there from 2000-2004 Montes with the l67
Old Feb 15, 2015 | 07:28 AM
The Riviera is a 97
Old Feb 15, 2015 | 07:04 PM
l67ss's Avatar
You can use the trans just gotta swapp a few parts over and wire the nss
whitemonte
16
Aug 9, 2017 11:14 PM
bigmyyke
Apr 14, 2014 11:11 AM
davidk67
May 10, 2012 09:21 AM
ve3oky
Oct 19, 2011 03:02 PM
Thunder_Horse`79
Aug 8, 2010 09:07 PM
