Will this size Rim and Tire fit my 2001 monte SS
doesnt the tire have to be smaller since the rim size is increasing, the tire has to be more "low profile"
what will happen with the bolt pattern will anything get messed up using these.? and what will happen if the tire is 225 and not 245?
I don't think you understand proper tire sizing.
But 245/45/18 is the correct size for an 18" rim on these cars. Trust me. I use it.
If you use an improperly sized tire, your speedo and odometer will be off.
ok ill buy the 245/45/18's but can i pull it off with the bolt pattern? 5x114.5
