Will this size Rim and Tire fit my 2001 monte SS
Old Apr 25, 2012 | 02:08 PM
16With01MonteSS's Avatar
Default Will this size Rim and Tire fit my 2001 monte SS
*18x8 Liquid Metal f5 rims
*5x114.5 bolt pattern
*38 offset
*Nitto NT555 Extreme tires
*225/45/18
let me know what u are thinking about this.. thanks guys! and girls?
Old Apr 25, 2012 | 02:48 PM
I wouldn't use a bolt pattern that wasn't 5x115
Also that tire size is 3% smaller than factory and I wouldn't use that either.
Old Apr 25, 2012 | 02:53 PM
doesnt the tire have to be smaller since the rim size is increasing, the tire has to be more "low profile"
Old Apr 25, 2012 | 02:57 PM
Enzo354's Avatar
STILL SLOW
If you are putting on 18 by 8 you might need a 245 tire. The 114.5 bolt pattern will fit. Not perfect, but it will fit without issues.
Old Apr 25, 2012 | 03:04 PM
what will happen with the bolt pattern will anything get messed up using these.? and what will happen if the tire is 225 and not 245?
Old Apr 25, 2012 | 03:15 PM
I don't think you understand proper tire sizing.
But 245/45/18 is the correct size for an 18" rim on these cars. Trust me. I use it.
If you use an improperly sized tire, your speedo and odometer will be off.
Old Apr 25, 2012 | 03:18 PM
ok ill buy the 245/45/18's but can i pull it off with the bolt pattern? 5x114.5
Old Apr 25, 2012 | 03:57 PM
I don't recommend, you can do what you want with bolt pattern.
A lot of people run 5x114.3. I just personally never would.
Old Apr 25, 2012 | 04:03 PM
why wouldnt you, what damage does it do.?
Old Apr 25, 2012 | 04:10 PM
This rim issue has been argued over and over. Some do and some don't. Some haev ran them with no problem for years.
