Why couldn't I
Old Oct 23, 2007 | 12:06 PM
BLACK ATTACK's Avatar
Photobucket
Monte Of The Month -- December 2007
Default Why couldn't I
Is there any reason I could not run a Zero offset wheel like the one below:
VS
The 45 offset they recommend for my car with wheels like below:
Other than the tire would stick out a little bit without flares being added to the vehicle? Would it affect handling, ride, or performance?
I just like the look of a dished wheel better than the flat appearance of today's wheels.
Old Oct 23, 2007 | 12:41 PM
Laserblue06ss's Avatar
Default RE: Why couldn't I
I was told by by several mechanics and tire dealers over the years that changing the offset puts different stresses on the axles and bearings,due to the load being moved from its original designed position,and will lead to premature failure of bearings,axles,brakes.and suspension.
Old Oct 23, 2007 | 12:42 PM
ExplosiveSoundz's Avatar
I'm sure you could... just check your spacing.. and have at it! Just be careful of rubbing on the inner wheel well..
Old Oct 23, 2007 | 01:07 PM
God_Bot's Avatar
I sure hope that it won't cause too many problems as I to prefer the dish look and if it works out than I will defiantly be looking into other wheel choices.
Old Oct 23, 2007 | 07:21 PM
wheelguy's Avatar
Laserblue is 100% correct. Remember when the Honda owners wrer putting 13" standard wires on their cars, PLEASE don't do that to your car. You can get wheels with a 3 or 4" lip it's just rounded to the center of the wheel but still gives you a dish & doesn't look bad at all.
Old Oct 23, 2007 | 08:31 PM
RocknSS04's Avatar
It will TRASH your steering and suspension. Just like extra wide wheels trash truck suspensions. Ball joints, tie rod ends, adding steering stabilizers (shocks for your tie rods). Been there, done that! No thanks. Keeping proper suspension geometry is critical, unless you have no plans on driving you car anymore.
Maybe some 22's like Discomonte's? Even then go to heavier suspension parts, like the Moog's.
Wayne
http://www.cardomain.com/ride/2319272
JC Colon
MCF Website Problems & Issues
Mar 25, 2015 10:32 PM
labnjab
Feb 16, 2010 04:10 PM
BLACK ATTACK
Dec 18, 2007 08:15 PM
rj
Oct 2, 2007 12:44 AM
04MonteLS
Nov 1, 2005 04:42 PM
