What tires for 22s on an 06?
Old May 26, 2008 | 08:14 PM
Dolo85's Avatar
Default What tires for 22s on an 06?
245, 255, 265? and what is the offset?
Old May 26, 2008 | 10:07 PM
04MonteLS's Avatar
Default RE: What tires for 22s on an 06?
I wish I could help you bro but welcome to MCF anyway.
Old May 26, 2008 | 10:25 PM
paddock's Avatar
oh a 245 tire, you're probably talkin an 8.5" rim.. the offset for that would be in the 42mm range.
Old May 26, 2008 | 10:27 PM
paddock's Avatar
but I really don't see a 22" fitting on the car unless you don't run any rubber at all. You're comin dangerously close to the bottom of the spring cup with a 245/35/20. That's enuf of a rubber band!
Old May 27, 2008 | 01:50 AM
04MonteLS's Avatar
there's a guy on 2kmc with a 06+ MC w/22" Asanti's on it.
Old May 27, 2008 | 07:22 AM
wiz kidd's Avatar
MOST 22" rims are 9" wide, which means you need a 265/30/22 or a 265/35/22 (this is what i have on my magnum) 245 will probably be too narrow, they're barely fit a lot of 20's
as for the offset thats something i'm not that good @, i would imagine you would want a low offset being a front wheel drive car, but i could be wrong, when i price out wheels i just tell the supplier to make sure its the right offset and bolt pattern...then they're responsible if its not right
Old Jun 1, 2008 | 02:58 AM
ncc918's Avatar
i had 245 35 20 on my old 07 and they rubbed man..its irritating and scary when ur stuf is rubbing---make sure u get it dun right and dont go too big or ul regret it
Old Jun 1, 2008 | 08:50 AM
04MonteLS's Avatar
ORIGINAL: ncc918
Is it possible you had the wrong offset?
Old Jun 2, 2008 | 01:37 AM
Dolo85's Avatar
Hey everybody, thanks for your help it is much appreciated. The place where I am ordering my rims at suggested the 22x8.5 on 245/30/22. I am also planning on getting some kind of lift kit if necessary. Hopefully this will do the trick because I am definitely going to do it right.
SUPER SPORT MC
Jan 5, 2010 07:22 PM
Xcato
Nov 9, 2008 09:15 AM
DK_3000
Aug 20, 2007 07:09 AM
DK_3000
Aug 9, 2007 07:46 PM
bonafidejonb
Apr 29, 2007 02:01 PM
