Traction control message
Old Oct 8, 2011 | 12:55 PM
eastnjman's Avatar
Exclamation Traction control message
Lately ive been getting this message every once in a while.What can cause this? Do my bearings need replacing?Everyones insights and oppions are welcome.Thanx in advance
Old Oct 8, 2011 | 06:24 PM
You probably have a bad hub.
Old Oct 8, 2011 | 08:20 PM
dbarn's Avatar
I had intermittent traction control lights and abs lights that traced back to being a bad electrical plug going into the hub on the drivers side front wheel, replaced it and so far so good...
Old Oct 24, 2011 | 03:38 AM
eastnjman's Avatar
thanx guys it helped alot
Old Oct 24, 2011 | 09:51 PM
04chevyboy's Avatar
could be from where the hub plugs into the abs wire has come loose
Old Oct 24, 2011 | 09:52 PM
nitehawkjcb's Avatar
Like most people have said, it's likely the hub or the ABS sensor/wiring
mwmarshall
May 14, 2022 02:43 AM
VictoryRedSled
Jan 15, 2013 10:41 AM
Anna
Jan 13, 2013 03:36 PM
Jul 8, 2012 08:27 AM
TGAbreu
Jun 7, 2007 08:32 PM
