Suspension or worse?
Old Sep 28, 2011 | 08:51 PM
mwjames's Avatar
Default Suspension or worse?
my monte was purchased with a bent strut/damaged strut tower. I replaced the strut and straightened the top of the tower. When I drove it down the road it handled much better less wobble and curve. I know I will need an alignment and possibly have to have the shop tweak the tower some more but heres the big question when I accelerate the wobble/shake gets much worse a friend told me possibly bent cv axle or something like that. What are your thoughts?
Old Sep 30, 2011 | 08:05 PM
kingreyna's Avatar
Were the tie rods replaced also. When I replaced my struts I went ahead and did both tie rods and when I drove it to the shop it was nearly undriveable. Once alignment was done everything was OK. If nothing looks bad maybe it just needs an alignment.
Old Oct 2, 2011 | 02:06 PM
mwjames's Avatar
My tierods do need to be replaced and an alignment is needed. any idea if my friend axle assumption may b correct?
Old Oct 2, 2011 | 08:00 PM
I'd start with an alignment first than if that don't help look into the axel
Old Oct 2, 2011 | 08:12 PM
Budsjlm's Avatar
I would start with tie rods and an alignment,
Old Oct 11, 2011 | 11:59 AM
mwjames's Avatar
alignment shop confirmed the bent drive axle also said a wheelbearings bad but tierods are good.
Old Oct 11, 2011 | 12:33 PM
Now that you know what is wrong are you gonna replace them both yourself.
S1knes
Jan 13, 2014 05:34 PM
06athena
Jun 20, 2012 08:25 PM
jimbo7
Aug 18, 2009 09:04 PM
RocknSS04
Feb 16, 2008 06:30 PM
04MonteLS
Nov 1, 2005 04:42 PM
