Spacer
Old Sep 28, 2008 | 03:47 PM
Enzo354's Avatar
STILL SLOW
Default Spacer
Well on my monte there is a spacer on the rear suspension, I dont know if that year came with them or not. But I figure if i take it out, the suspension will be WAY too soft. Is there any kind of thing like a reverse spacer, to hold 2 parts of the springs together, instead of apart, or would it affect handling??
Old Sep 28, 2008 | 05:12 PM
JD87SS's Avatar
Default RE: Spacer
There is a spacer in the springs now holding them apart?
By all means remove it.
Spring rating is based upon the coils being able to compress as a team.
Spacers effect the spring capabilities big time while weakening the area where it resides until a weak link collapses.
Either way, holding them together or apart is old school, cheap mickey mouse tactics.
I could never believe they would ever use them stock when a redesign would be very simple.
Old Sep 28, 2008 | 05:48 PM
Enzo354's Avatar
STILL SLOW
Default RE: Spacer
So i can take it off pretty easy im sure, but will it bee too soft in back then??
Old Sep 28, 2008 | 06:46 PM
JD87SS's Avatar
Default RE: Spacer
A spacer won't make it stiff per say.
Its holding a section of coil so it can't collapse like it should.
Its does not change the spring overall rating, just limits travel.
Old Oct 4, 2008 | 05:22 PM
Teacher's Avatar
Default RE: Spacer
Did you buy the car used? I wonder if soemone would have done that to keep the rear from sagging or rubbing with a large stereo and larger wheels.
Old Oct 4, 2008 | 07:30 PM
Enzo354's Avatar
STILL SLOW
Default RE: Spacer
Yea i bought it used, and that could be too.
Old Oct 4, 2008 | 11:23 PM
Teacher's Avatar
Default RE: Spacer
Just think if you pull the spacer out and it is to soft for your liking then it just another reason to buy some eibach springs.
Old Oct 7, 2008 | 08:43 PM
Enzo354's Avatar
STILL SLOW
Default RE: Spacer
Once im not alot in the hole, i def will haha.
Old Oct 7, 2008 | 08:54 PM
Teacher's Avatar
Default RE: Spacer
I here you there.
MadelynsDaddy
Aug 10, 2007 12:24 PM
Bml97MC
Apr 1, 2007 03:12 AM
2000_BLACK_SS
15
Aug 29, 2006 02:20 PM
01pacecar
Jun 26, 2006 04:41 PM
Monte Python
May 20, 2005 02:56 PM
