slow leak- seal problem? 06 ss
Old Feb 10, 2011 | 04:44 PM
Slugger088's Avatar
Monte of the Month -- August 2013
Default slow leak- seal problem? 06 ss
Hey guys,
I just got my 06 monte ss back in november and drove it for a month before all the snow here in Ontario began to fall. Since then its been stored away for the winter. We have had extremely cold weather here for the past few weeks. The other day I went into my garage and the rear passenger tire was almost flat. I'm almost positive I didn't get a nail in it, but I've heard aluminum rims have a history of leaking. Has anyone else had this problem with their stock rims on their ss. Anyone else had this problem in the cold weather? Possibly a seal problem? Any thoughts would be appreciated.
Old Feb 10, 2011 | 04:52 PM
LuSe4's Avatar
Mine don’t leak at all. You probably picked up some kind of debris and it has a slow leak, or your tpms sensor/ valve stem is leaking.
Old Feb 10, 2011 | 04:58 PM
Blazed SS's Avatar
IT HERTZ
I have never ha a problem with any of my aluminum rims on any of my cars having a slow air leak. I would air up the tire and get some soapy water and check the valve stem both around the bottom of the stem an remove the cap and try some soapy water there 2 and see if you get any bubbles and the you can go around the bead of the tire on the out side and the back side and check for leaks most tire shops are cool to check this for you also good luck
Old Feb 10, 2011 | 05:01 PM
Slugger088's Avatar
Thanks for quick reply luse4.. Yea I'm gonna check into it. That's another thing.. How should the tire pressure be displayed on the info center all four of my tires show a reading of " - " even though I pumped them all full with the correct air pressure. I even did the test (forgot the exact thing is called) where the horn honks to measure the air but it remained "-" .. Should it actually be showing the exact pressure in the info center? Or is something wrong with my TPMs sensor?
Also, if u go with aftermarket rims do your have to have the tmps sensor placed on the new wheels?
Old Feb 10, 2011 | 05:52 PM
here are 2 pics from my car and the TPMS measurements... front right is dead on my car currently and if you switch wheels you need to transfer the TPMS sensors because they are inside the valve stems..
Old Feb 10, 2011 | 06:03 PM
Slugger088's Avatar
hey man thanks alot. Yea you see what your says for front right, well that "_" is whats showing for all my tires and I know for a fact it has the right amount of air as I checked them all with my tire pressure gauge. what do you think the problem is? all of them are dead? I mean i guess its not a big deal but it would be conveinent to know if im low by looking at the info center and I cant stand when something should be working and its not.
Old Feb 10, 2011 | 06:25 PM
I'd hate to think all of them are bad? There is some sort of re-learn procedure but I never messed around with it, can't help you there.. is the -- in the pic I posted the same as what you're seeing on yours? The symbol you posted is different in both posts that you made?
"_" and " - "
this is the current status of my TPMS sensors, because I had winter only tires mounted and took out the sensors, I'm going to get new wheels in the spring and I will get all new sensors then. they cost about $150 for all 4 at tirerack.com
current: front and back
Old Feb 11, 2011 | 09:01 AM
Slugger088's Avatar
"_" and " - "
Yea, the reading im getting is identical to the reading that is showing in the pics you posted the "--" on all four wheels. The car has hardly any milage on it so I doubt the tires were even changed but then again its possible. And as far as the relearn procedure I tried it twice and you have a total of 2 minutes to follow a certain procedure with all four wheels. Pretty annoying to be honest and the more I think about it, its not even that great of a feature and I'd rather just check it manually with a tire guage every weekend or something.
Old Feb 12, 2011 | 08:54 AM
TheMonteMan's Avatar
there was a tsb for the tpms. malfunctioning. mine were replaced under warranty for a similar issue.
Old Feb 13, 2011 | 12:44 PM
Slugger088's Avatar
Turns out the tire was already plugged twice and one of the plugs was leaking. The last owner must have made a habit of driving over nails. I replaced the plug that was leaking and we'll see if it holds up. The tires probably have another summer left, the treads are still pretty good but we'll see. Most likely getting some new wheels this summer anyway.
Thanks guys/
Charleslatrelle
Mar 16, 2015 07:19 AM
killerBee
Mar 20, 2013 09:02 AM
Joe Bloggs
Feb 8, 2013 08:26 AM
Montecarloguy07
Nov 17, 2011 11:22 AM
mickey
Jan 22, 2007 05:52 AM
