6th Gen ('00-'05): Should I lower the rear also?
Old Apr 22, 2013 | 09:51 PM
ar3em11's Avatar
5 Year Member1 Year Member
Default Should I lower the rear also?
I started the lowering of the monte, unfortunately half way through I had an emergency at work and did not have time to finish. After looking at her now though, I am not sure if i want to put the springs on the rear, just the struts possibly. Thoughts? The picture is about an hour after finishing the front springs.
Old Apr 22, 2013 | 10:54 PM
Honestly it's a little difficult to tell in that picture. Maybe some different angles? A profile shot from the side would help a lot.
Old Apr 22, 2013 | 11:02 PM
ar3em11's Avatar
I thought the second pic posted. This is a bit better.
Old Apr 22, 2013 | 11:30 PM
I would lower the rear still. More of a sleek aerodynamic appearance. Not trying to be a muscle car jacked up with fat rear tires. Center of gravity is a touch lower to and would make the Monte hug the road even better. Mine is lowered all the way around.
Old Apr 23, 2013 | 07:24 AM
Do you have any added weight in the back like subs? I only lowered the front one mine
Old Apr 23, 2013 | 07:45 AM
Ha your good, that is a very valid consideration. What do you plan on doing with your Monte. Subs, rear passengers ever? See it pays to ask the pro's, I won't have either of those issues, so was not thinking along the lines.
Old Apr 23, 2013 | 08:03 AM
ar3em11's Avatar
passengers no, I do currently have subs in the trunk. I just dont want the front to end up higher than the rear.
Old Apr 23, 2013 | 08:20 AM
This is how mine looks all I got is 2 12" subs in the rear with stock springs and lowered 1.7" up front
Old Apr 23, 2013 | 08:36 AM
This is how mine looks, lowered all around with one 12" sub in the trunk (1.8" drop in front and 1.5" drop in rear). The rear still sits a bit higher with that added weight and overall it sits nicely.
Here's a more recent picture straight on from the side.
Old Apr 23, 2013 | 01:56 PM
tps221's Avatar
you guys are making me wish i had the money to lower Lola.
Sootah
May 9, 2012 09:42 PM
dezzyboi16
Mar 13, 2011 08:11 PM
Aug 16, 2010 10:38 AM
aw9d
Oct 31, 2009 02:24 PM
00SS
Aug 9, 2006 05:02 PM
