shaking at 55mph-60mph in an 87ss
Old Aug 5, 2009 | 12:48 PM
Jimbo's Avatar
Default shaking at 55mph-60mph in an 87ss
ok so first off my dad thinks this is just because it needs a high speed rim adjustment or something like that but at about 55mph or 60mph my 87ss shakes like alot but then if i increase my speed it doesnt matter just the 55-60mph range it used to be 65-70mph but it changed idk why that is its just that mph range its odd any clues on the problem?
Old Aug 5, 2009 | 12:58 PM
Budsjlm's Avatar
probably just a wheel balance issue or if the car had been sitting for sum time on the tires a flat spost can acure where it has been sitting...id say probably just needs to be rebalance
Old Aug 5, 2009 | 01:08 PM
Jimbo's Avatar
no i can let go of the wheel and go perfectly straight and if there were flat spots why is it only shaking in the 55-60mph range and not higher or lower speeds
Old Aug 5, 2009 | 01:12 PM
Budsjlm's Avatar
thats kinda odd that its not higher or but like i said probably just needs to be rebalance(hight speed alignment as u called it) is it comming from thr front end? does the wheel shake ?
Old Aug 5, 2009 | 01:25 PM
Budsjlm's Avatar
id say call around get prices on a wheel balance and go get it done..more than likely will solve your problem but id say if ur driving it do it if your not dont bother especially since
Old Aug 5, 2009 | 01:27 PM
Budsjlm's Avatar
your talking about getting your rims reconditioned becuase the tires will have to come off for it anyway...and then mounted back on and balence
Old Aug 5, 2009 | 02:07 PM
RickAKATed10's Avatar
Photobucket
I'd say have the wheels rebalanced or at least have a shop check to see if they are balanced.
Old Aug 5, 2009 | 02:26 PM
Jimbo's Avatar
well my dad owns a shop so i dont have to look for prices idk ill find out by winter for sure which is when its going to be painted and all that just thought id get some suggestions just in case but my dad knows for sure what is wrong hes a good bodyman and pretty good mechanic
Old Aug 6, 2009 | 12:01 AM
Toasty's Avatar
classic symptom of a wheel being out of balance is vibration between 55-60 mph range. That's not to say it won't go straight if you let off the steering wheel. We're not talking about alignment here, just tire/wheel balance.-- there are actually 2 different parts to balance a wheel/tire combo-- in a nutshell- static balance balances the tire up/down, dynamic balance balances left/right. if you've thrown a weight, or even have excess rocks in your tread, you can throw off the balance in either direction...
now, there is the outside chance (though very small) that there is a belt starting to separate in a tire, but that usually results in a different feeling in the car, and a different 'womp-womp' sound at low speeds.
Old Aug 6, 2009 | 01:36 AM
Jimbo's Avatar
k thank you thats exactly what my dad was talking about
loudNproudSS
13
Aug 7, 2020 12:01 AM
87SS_builder
Aug 19, 2013 10:06 PM
Jimbo
Aug 6, 2009 05:47 AM
loudNproudSS
Apr 20, 2008 06:53 AM
1987SS
Jun 20, 2007 02:14 PM
