Rear STB bar
Rear STB bar
I was just wondering if anyone has tried putting an STB on the rear towers of the 00-05. I'm wondering because I will be getting into racing the car a bit more next year on road courses, and am looking to stiffen up the suspension a bit. At the moment I have the GMPP sway bar upgrade kit with poly bushing up front and moog endlinks in the rear, Eibach lowering springs, and KYB AGX 4 way struts, and the car came stock with the front STB.
Anybody with any experiences with the rear STB, your input and experience is much appreciated
Thanks,
David
Thanks,
David
werent you suppose to be making more for us 06-07 gens?!
http://www.wbodystore.com/grandprix/...ace-p-121.html#
I was thinking of something more along the lines of that style with the ring around the tower, but the rings would be welded to the gm stb.
I posted this because Im more wondering how the car reacts or handles with the rear stb. I was hoping to get some replies from people with them so they can share their experiences, like if the car goes back into understeer or if it oversteers or anything like that.
I do appreciate your help and the new links though. Now i have somewhere to get parts when I get this moving along.
basically what i did was get the GM STB bars kit and draw a don rome-like shaped bracket around the mounting holes on the template that came with the STB bar kit. therefore, if you buy or already have the kit, you could probably make better ones than i have right now. let me know
i have front/rear stabilizer bar with don rome brackets. i can feel the suspension more stiffer. when i was at the track doing burn out i feel the front tires stay put and not moving side to side than before. overall i think it helps a lot.
yeah i still have them around, BUT i never said much about them because i could have done a better job making them, haha. when i was all done, i still had to do lots of filing and fitting to get it to fit the way i wanted it to. then i welded 3/8" threaded studs in the brackets for an easier install. i don't even have the rears done yet so i don't know how they fit. work has been crazy so i haven't had time to cut them out. plus our bandsaw has been down for a couple months now
