putting rims on 87 Ls pls read
Old Jun 14, 2010 | 10:37 PM
Aobclanlead's Avatar
Default putting rims on 87 Ls pls read
So yeah im getting some 22s for cheap.. and i already know bolt pattern is differant cause they came off of a Mercedes S5OO
basically i would like to know if information i got is correct or not... please if something is wrong let me kno...
Im buying adapters
the 22s bolt pattern is 5x112 center hub 66.5
my origonal bolt pattern 5x 4.75 Center hub 70.3
adapter kit 5 Lug to 5 Lug Wheel Adapter: 5 X 4.75 to 5 X 112 was gonna get hub same as monte origonal... so any info pls let me know
thanks for taking time to read
Old Jun 15, 2010 | 01:09 AM
Budsjlm's Avatar
i'm not sure of the centerbore but the bolt pater is right you may have issues with the fronts becuase unlike the newer cars the front hub/bearing stick out into the rim a bit you may have issues with that you may need to get the centeres of your rims bored out a bit to fit properly
Franks 03SS
Aug 9, 2011 07:55 PM
RickCoMatic
Sep 13, 2010 07:30 PM
jcallahan
Jun 12, 2010 05:52 AM
2000_BLACK_SS
Jun 1, 2009 07:35 PM
liamrh
May 12, 2008 10:24 PM
