Ok another Rim question
Old Apr 5, 2010 | 10:14 PM
Dhdolphns's Avatar
Default Ok another Rim question
Once again let me point out that I am new to the forum and owning a monte carlo..
I have a 2002 SS and have access to the S/C 17" 235/55/17 wheels/tires and was wondering if anyone that put these on had any problems??
Does the S/C have a diffrent suspension that the regular SS?
I assume there wouldnt be, but I also am old enough to know not to assume..
THANKS
Old Apr 6, 2010 | 09:25 AM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Im not sure about the tire size but they sound like they will fit and no, the s/c does not vary from the SS suspension. I have 18" on mine if height is what your concerned about you should be fine hope this helps a lil!
Old Apr 6, 2010 | 09:26 AM
You should be able to run those with no problems, but I believe the recommended width is 225 for us, so just keep an eye on the strut plate after you install them.
Old Apr 6, 2010 | 09:41 AM
MAMONTE's Avatar
You will be fine with the 235 I think. Brock, member ENZO354 put the 17" Dale wheels on his 00 SS, and I think he has the 235/55/17 tires on it, and its working. You may PM him just to make sure everything was a bolt on.
Old Apr 6, 2010 | 10:07 AM
Dhdolphns's Avatar
thanks for the info,
the 235/55/17 are a little taller than the 225/60/16 but it wasnt hitting the strut plate but was a little tighter fit.
I still cant see why they wouldnt fit, but I have seen posts before about the dreaded strut plates on some wheels, and it never hurts to try to find out all one can..
Old Apr 6, 2010 | 10:09 AM
Enzo (Brock) had to pound his rear strut plates
Old Apr 6, 2010 | 10:39 AM
RickAKATed10's Avatar
Photobucket
I doubt you'll have any problem.
Tadcaster
Jun 15, 2015 06:04 PM
djhodge05
Sep 11, 2009 11:51 PM
kaligoman
Apr 20, 2009 11:17 AM
06 Monte LT
Oct 12, 2008 11:10 PM
SSmokybear
Mar 17, 2008 03:52 PM
