Nose down??
Old Apr 21, 2012 | 10:53 PM
04intimidatorssjmm's Avatar
this is what she looks like at the moment, excuse the stock wheels she will have the killers back on when the weather is nicer. P.S. why would i need camber bolts my wheels look fine as far as camber is concerned
Old Apr 22, 2012 | 12:23 PM
kingreyna's Avatar
Thats exactly how mine looked and never settled Camber bolts may be needed on some. Firestone couldn't get them properly aligned unless I used some caber bolts. Good thing I had lifetime alignment or I'd be screwed there.
Since you lowered it it no longer sits at factory height. Things get misaligned and what not. Your engine also leans further back now. Thats why shorter dogbones are used also. Same thing about the front axle isn't aligned straight and shorter dogbones help that also.
I forgot most of the details though. Everything about lowering can be found here with some time and searching. Here are two of my threads:
https://montecarloforum.com/forum/ti...veryone-29209/.
https://montecarloforum.com/forum/ti...d-06-lt-28635/
Good luck
Old Apr 22, 2012 | 02:36 PM
greeeat well i have been talking to zzp so hopefully they can do something cause this is bs
Old Apr 22, 2012 | 08:02 PM
so took the ol girl for another short spin today to try and "settle" the rear springs and had no luck what-so-ever startin to get quite irritated
Old Apr 23, 2012 | 09:07 AM
Question for you.
Now it could be a stupid question, I haven't lowered my car. Aren't the front and rear springs different heights to begin with? Perhaps the wrong springs were put on the wrong end of the car?
Old Apr 23, 2012 | 10:49 AM
Budsjlm's Avatar
just get a 2 fat chicks to ride around in the back seat for a day or two it should settle
seems to be working for this mustang
Old Apr 24, 2012 | 06:30 PM
Question for you.
i thought of that also and even though i havent taken them off (the weather sucks here) they look the same as ZZPs picture of their drop in assembly wider gap and wider seat springs on the rear with the fixed mount, tighter narrower seat spring in the front with the swivle mount
Old Apr 24, 2012 | 06:34 PM
lol @budsjlm but i love my monte so no livestock allowed lol
Old Apr 25, 2012 | 12:43 AM
you need to give them a chance to settle.
the fronts are way stiffer than the back because of the engine, but the rears are also going to take a while to settle because there is no weight back there to help them settle.
remember, these are BRAND NEW struts and springs, its not like you're lifting up your stock struts and springs and lowering it again where it'll drop in a day or two again.
Old Apr 25, 2012 | 08:46 AM
Mike 00LS's Avatar
Maybe put a sand bag or 2 in the trunk to give it some extra weight and help them settle.
