Nose down??
Old Apr 20, 2012 | 08:12 PM
04intimidatorssjmm's Avatar
Default Nose down??
so i just had some work done on my 04 ss part of which was the installation of KYB GR2 struts, ZZP lowering springs (i think they are actually ssc springs) and new top mounts but now the front looks alot lower than the rear. i did notice that my stock washers were re-used instead of the new anti pogo ones but this shouldnt change the ride height right? so any ideas or is this normal on our cars? i will post a pic tomorrow
Old Apr 20, 2012 | 08:35 PM
Was the work JUST done? Let the springs settle before you see if something is wrong.
Old Apr 20, 2012 | 08:54 PM
MONTE2000SS's Avatar
i was gonna say the same thing chibi
Old Apr 20, 2012 | 08:57 PM
BlackRainSS's Avatar
Can't wait to see pics!
Old Apr 21, 2012 | 10:50 AM
i will give it some time but it just seemed wierd that the front settled right down but the back didn't it almost looks stock in the back but we will see
Old Apr 21, 2012 | 11:27 AM
The front has the weight of the engine... the back doesn't
Old Apr 21, 2012 | 12:15 PM
kingreyna's Avatar
I had the same thing happen to me with your identical setup. The rear never settled on mine. The rear looked stock while the front was lowered. I removed them a couple of months later. I also didn't like how it felt which was a big disappointment.
Good luck. Hopefully they will settle.
If not there must be something wrong with a KYB GR2 and ZZp sping combo.
Old Apr 21, 2012 | 03:19 PM
i hope so i have driven it about 10 miles and still not settled plus it now has a shutter under moderate to hard acceleratio, is this the vibration people usually get and fix with shorter dog bones? the car did sit all winter so i figure its either the drop or the sitting that is causin the shutter any thoughts?
Old Apr 21, 2012 | 06:14 PM
kingreyna's Avatar
Well remember to get an alignment afterwards and you will need some caber bolts. The rears didn't need it on mine but the front did. I have the shorter dogbones and 2 camber bolts I could sell you cheap. I don't need mine anymore.
I think the shorter dogbones do reduce the vibrations if I recall. I had them installed also on mine.
Old Apr 21, 2012 | 10:49 PM
the alignment was done at the shop right after they installed the springs and did the engine work and they test drove it but only a short distance on city streets to make sure there were no leaks
