New Wheels!!
#44
Thanks Vincent. The wheels and tires, brand new from TireRack.com. It was about $1100-$1200 shipped to my door.
As for the calipers/brakes, in the works. The car is covered for the winter and I pulled the calipers off a couple weeks ago. A friend of mine will be blasting them and then off to powder coating
#46
What made the car "settle" on its own? It knows not what tires/rims are on it, nor the spacing left in the wells. I am lost here ... Almost more than I have ever been when it comes to something automotive.
#47
When you jack a car up, it fully extends the suspension when the wheel is off the ground (such as stretching the coil springs, allowing the struts to go their max distance and a host of other small things). Most of the time when you put the car back down (putting a load back on the suspension) you don't notice if it's resting a little higher then normal.
In this case with the new wheels, resting a little higher then normal is more noticeable. Once you take it for a little drive or sometimes letting it sit, gravity pulls the suspension back to normal.
Hope that helps
Hope that helps
#49
It's not about how long the suspension is hanging, it's about the fact it is hanging. It's fully extended.
Either that or it's the placebo effect..... lol
