Lowering
Old Dec 9, 2013 | 04:54 PM
tweek's Avatar
Default Lowering
Can anyone verify this for me? I was told when putting on lowering springs that you need to use eccentric camber bolts is this true?
Old Dec 10, 2013 | 07:06 AM
No.
In some cases yes but those are usually extreme cases where the car is being dropped a significant amount. Most typical lowering doesn't require them. I've lowered both my 03 Monte Carlo in the past (Eibach Pro-Kit lowering springs; 1.3" drop) and my current 06 Monte Carlo (CM lowering springs; 1.8" drop) and have not installed camber bolts in both situations and have been just fine.
I actually made a thread about camber bolts a while ago so reading through this would help as well > https://montecarloforum.com/forum/ti...r-bolts-41182/
Old Dec 10, 2013 | 08:38 AM
tweek's Avatar
Im just going by what my friend said. He is a service manager at firestone tires. All he said that I would need them so I dont wear out the inside of the tire. But since now I know you have done it without I wont worry about it.
Old Dec 10, 2013 | 09:17 AM
As long as your alignment is in check you shouldn't have an issue with premature wear on the inside shoulder of the tire. I had brand new Michelin Pilot Super Sports installed on my 06 in April earlier this year, had them do an alignment as well, and after 3k miles this summer the tires aren't showing anything abnormal.
Old Dec 10, 2013 | 04:35 PM
07ss_ls4's Avatar
To lower a 07 SS do u need 1.5 for the front and back or 1.5 in the front and 1.7 in the back?
Old Dec 10, 2013 | 06:16 PM
Unless you have the springs custom made with the drop you want (more expensive), you buy the lowering springs as a kit so you get whatever the advertised drop is for the kit. I'm running Canuck Motorsports lowering springs on mine and their advertised drop is 1.8" in front and 1.5" in back.
Old Dec 10, 2013 | 11:11 PM
07ss_ls4's Avatar
Oh cause this guy i know lowered his 1.5" for front and back and the front looks lowered but the back doesnt. It still looks stock hight
Old Dec 11, 2013 | 07:51 AM
Those wouldn't happen to be ebay springs he went with would they? I would not recommend ebay springs because, from what I've seen, they're a huge gamble as they don't seem to correctly lower to their advertised drop specifications; the front may lower but the rear may not (like you said), or vise-verse depending on the specific situation.
Old Dec 11, 2013 | 08:49 AM
tweek's Avatar
I went with canuck motorsports I havent put them on yet. For my 2004 SS its advertised 1.7" in the front and 1.3" in the back
Old Dec 11, 2013 | 10:52 AM
The car should look great when you get those installed, good choice on CM.
