Lowering
Can anyone verify this for me? I was told when putting on lowering springs that you need to use eccentric camber bolts is this true?
No.
In some cases yes but those are usually extreme cases where the car is being dropped a significant amount. Most typical lowering doesn't require them. I've lowered both my 03 Monte Carlo in the past (Eibach Pro-Kit lowering springs; 1.3" drop) and my current 06 Monte Carlo (CM lowering springs; 1.8" drop) and have not installed camber bolts in both situations and have been just fine. I actually made a thread about camber bolts a while ago so reading through this would help as well > https://montecarloforum.com/forum/ti...r-bolts-41182/ |
Im just going by what my friend said. He is a service manager at firestone tires. All he said that I would need them so I dont wear out the inside of the tire. But since now I know you have done it without I wont worry about it.
As long as your alignment is in check you shouldn't have an issue with premature wear on the inside shoulder of the tire. I had brand new Michelin Pilot Super Sports installed on my 06 in April earlier this year, had them do an alignment as well, and after 3k miles this summer the tires aren't showing anything abnormal.
(Post 585032)
Originally Posted by 07ss_ls4
(Post 585092)
To lower a 07 SS do u need 1.5 for the front and back or 1.5 in the front and 1.7 in the back?
(Post 585111)
Unless you have the springs custom made with the drop you want (more expensive), you buy the lowering springs as a kit so you get whatever the advertised drop is for the kit. I'm running Canuck Motorsports lowering springs on mine and their advertised drop is 1.8" in front and 1.5" in back.
(Post 585149)
Oh cause this guy i know lowered his 1.5" for front and back and the front looks lowered but the back doesnt. It still looks stock hight
I went with canuck motorsports I havent put them on yet. For my 2004 SS its advertised 1.7" in the front and 1.3" in the back
Originally Posted by tweek
(Post 585200)
