lowering
short d-bones are crap! never used them but heard they doesn't help. x2 on the spacers. another way that help with the vibration is to turn the rubber inside the upper mount. i don't remember if mine still vibrate or not. i use intense poly mounts in mine.
the only thing i noticed that the 7th gen and the 6th gens differ is the headlights and grill. also the engine packedge and lack of a few things like headers being able to get a better tune for the pcm as in speed limiter but not much changed i wish that there were the 3.8 all the way to the 7th gen what i mean the 7th gen having the 3800 and 3900. but i dont mind the 3500 vvt.
I third this point! The shorten dog bones are the cheaper easier half fix. With the shorten dog bones I thought I heard your putting more twist than not on the axles. Don't quote me on that. I have to find the post where I read this. I am getting ready to put my order to a vendor to getting my strut mounts and motor/trans spacer.
stiffer dog bones
If you want to firm up the engine movement, you need to look into doing poly mounts for the ends of the dogbones. Replacing the square front ones makes a pretty big difference, replacing the round rear ones makes a much smaller difference (since they're solid rubber to start with).
I don't believe there are any stiffer dog bones. There is a company that makes the billet ones, but they're pricey- and I doubt they're significantly stiffer than the stock ones.
ther's a guy on clubgp and zzp selling the transmission and motor mount metal square piece that is suppose to help with vibration on lower cars. i'll find the link later.
here is something to think about if you gonna lower your car you will feel every bumps on the road and the ride will not be as smooth as stock. also if you might have to roll the fender lip if you go with wider tires.
That's a good point you bring up about lowering, though! Anyone not wanting to sacrifice a little smoothness on the road shouldn't lower their car either. Especially since stiffer struts are also recommended for that setup.
This is the difference between owning a "luxury performance" vehicle and a "sport performance" vehicle. If you want to cruise quietly and enjoy your ride, keep the car stock or buy a Caddy. If you want to play, then modify your Monte and don't complain. Then drive a modded F-body and really see what rough/loud feels like.
