LOW TIRE PRESSURE
Old Jun 10, 2007 | 01:42 AM
turner_dtp's Avatar
Default LOW TIRE PRESSURE
hey whatsup guys,
tuday i bought brand new tires for my montecarlo and about 1 mile into driving my car the LOW TIRE signal flashed and is still on. My front left tire looks a bit low but i cant find my tire gauge and im too annoyed by all the little details that have been going on with my car. The guy at the tire shop says that i need an alignment. I guess tomorow ill take it to my dad, but i wouldnt mind anyones help.
thanx!
P.S. dont take calculus-II in a summer session, it's stressful.
DEUCE!!
Old Jun 10, 2007 | 08:50 AM
wiz kidd's Avatar
Default RE: LOW TIRE PRESSURE
shouldn't be an alignment thats causing that...is your monte an new one?? because it could be that they didn't re-install your sensors properly or @ all
Old Jun 11, 2007 | 01:46 AM
2000LS's Avatar
on a 00-05 if you dont reset your tire light after: replacing tires, replacing wheels, rotating tires, or even just adjusting the tire pressure to be right at recommended pressure, you may tigger the low tire light to come on. basicly, reset the tire light whenever you touch em.
Old Jun 11, 2007 | 07:34 AM
wiz kidd's Avatar
and how do you reset the tires??
Old Jun 11, 2007 | 08:27 AM
Laserblue06ss's Avatar
Turn key to ON but don't start the car,turn parking lights on and off 3 times within 5 seconds and system should reset.I had the same thing happen on my 2000 and those are the instructions in the owner's manual.New tires change the rotation slightly and that is what the monitering system reads on the 2000-2005 cars.
Old Jun 11, 2007 | 11:49 AM
2000LS's Avatar
00-05 i do it thought the radio, its the next selection after the oil life monitor
Old Jun 15, 2007 | 08:18 PM
turner_dtp's Avatar
tahnks
guys!!
Old Jun 18, 2007 | 09:20 PM
Bigg J's Avatar
Yup, that really all you can do is to make sure the pressure is correct and that there are no leaks in the mounting. After that, reset the monitor sensor and you should be cool.
montejass
FWD Tech Guides '95-'07
42
Sep 22, 2021 10:19 AM
big green dog
Mar 14, 2012 02:56 PM
tlip06
Oct 7, 2007 09:37 AM
amberblk00
Sep 12, 2007 03:03 PM
keghead40
Jul 19, 2005 12:13 AM
