Impal 04 struts for a 6th gen Monte ?
Old Apr 22, 2014 | 02:01 PM
MJClemm's Avatar
Default Impal 04 struts for a 6th gen Monte ?
Anyone know if struts from a 04 Impala will fit into the 6th gen Mintes ? The ride from the impala is so much smother than my monte and want to switch it over for a smother ride.... Help !
Old Apr 22, 2014 | 03:59 PM
I just did a cross reference on RockAuto.com and they claim '04 Impala front and rear struts do fit the '00-'07 Monte. Based on that, I think you would be fine.
The next question is, are the genuine GM struts for both vehicles actually different or is it the comparison of one vehicle has a really worn out set of struts and the other does not (or were the struts changed on one of the vehicles already).
Old Apr 22, 2014 | 04:10 PM
solaris_vii's Avatar
its my understanding they had the exact same struts from the factory, so sounds like one is more worn out than the other
Old Apr 22, 2014 | 04:29 PM
l67ss's Avatar
difference is in the springs, monte ss got fe2s, impala got anything from fe1-fe4s
Old Apr 22, 2014 | 04:58 PM
tps221's Avatar
the 2000-2004 monte ls use the same setup at the 2006-2011 impala ls
Old Apr 22, 2014 | 05:00 PM
l67ss's Avatar
and theyre bolt in on the rear of fifth gens too
Old Apr 22, 2014 | 05:06 PM
tps221's Avatar
exactly and now that the springs have settled it handles so well in the corners minimal tire squeal flying on and off highway ramps its such a nice change to have higher limits.(compared to a bounceing and sliding rearend)
Old Apr 22, 2014 | 06:11 PM
03SSLE's Avatar
The only thing you really need to watch for is strut height. The struts for the 16" wheels is shorter, so if you got a strut for 17" wheels (and have 16" wheels) you will have a fitment problem.
Old Apr 22, 2014 | 06:38 PM
MJClemm's Avatar
What would the smoothest springs be ? I don't want a stiff ride anymore... Ravings all done now...lol...
Old Apr 22, 2014 | 06:40 PM
MJClemm's Avatar
I just installed brand new Kyb struts on my Monte SS... The struts work great. But the ride is stiff as all hell.... That's why I want diff struts / or springs... For the smoothest ride, what would you recommend ? Thanks everyone....mjclemm...
