Good Summer tires
Old Jan 6, 2010 | 06:33 AM
labnjab's Avatar
Question Good Summer tires
I was wondering what would be a good summer only tire? 235/55R17 V rated The hancook optimos I have now just suck. They don't have anything for traction. The Goodyear rep that comes into the garage I work at says the Goodyear Eagle F1 are great...but he is a salesman so he could be trying to make a sale. Does anyone have experience with it? Hows it grip. Any suggestions? I run snow tires in winter so it only has to be good on dry ground and rain.
Thank you for any suggestions
Old Jan 6, 2010 | 07:28 AM
I myself don't have any experience with the F1, but I have some friends with newer Mustangs and they swear by them. I would probably choose those if I were to pick a summer tire.
Old Jan 6, 2010 | 08:38 AM
RocknSS04's Avatar
We have Goodyear F1 tires on 2 cars. 245/45-18. Both on the Monte and the Solstice. Maybe not the BEST tire, but I have no complaints. I put them on the Monte for under $500 out the door. I'd do it again in a heart beat.
When looking for tires, I look for at LEAST a 400 AA A rated tire, unless the price is REALLY good, and I want an AA A rated tire no matter what. AA rating for traction, and the 2nd A rating for temp. 400 is the wear rating (just an FYI for those that don't know).
Michelin has a 500 AA A rated tire, the Pilot Sport A/S Plus, but at $50/tire more, I'd stick with the Goodyears.
Look for REBATES! Goodyear has an $80 rebate right now, and that brings it down to $137/tire for the F1's
Old Jan 6, 2010 | 10:55 AM
RickAKATed10's Avatar
Photobucket
www.tirerack.com
There are a ton of great summer tires. Happy shopping.
Old Jan 6, 2010 | 11:21 AM
MAMONTE's Avatar
X2 on checking out Tirerack.com you can really get a lot of valuable info off their website from other people that have used the tires. Plus when looking to buy, Tirerack has excellent prices!
Old Jan 6, 2010 | 11:48 AM
labnjab's Avatar
Thank you for the suggestions. I forgot about tire rack. I'll probably use it to see whats out there but buy them at cost from work. I may go with the f1's. I just wanted to see if someone had 1st hand experience with them on their monte. I'm not looking for the greatest tire, just something that grips a little better so I'm not always accidentally spinning the tires.
The garage I work at is a Goodyear dealer (has been since the early 1900's too) and employees can get special factory direct prices on tires so I can get them dirt cheap
Is there an alternate size I can put on the Dale JR wheels, something maybe a little wider?
Old Jan 6, 2010 | 11:59 AM
MAMONTE's Avatar
I think the Dale wheels use a 235 width, which is already a little wider than the typical Monte tire which is a 225...IDK if you can go even wider or not???
Wayne is running 245's but he is using an aftermarket rim.
Old Jan 6, 2010 | 01:00 PM
Enzo354's Avatar
STILL SLOW
Im not sure if you can go over 235 or it will be bulging a bit out the sides and probably give you a good sidewall flex.
KINGBASS
Jul 1, 2015 04:14 PM
BeachBumMike
Jun 7, 2014 12:58 PM
GoodZwell
Feb 21, 2013 08:22 AM
Aug 6, 2012 05:23 PM
06MonteSS
May 7, 2006 01:32 AM
