2nd Gen ('73-'77): Finally got some rims for my monte, what is a good tire size that will fit?
Old 03-04-2014, 02:12 PM
brady73monte's Avatar
Default Finally got some rims for my monte, what is a good tire size that will fit?
I just got from Summit a set of American Racing outlaw series rims for my monte carlo. They are the same look as the centerlines and they where cheaper with free shipping. I got 15x 8's for the back and 15x 7's for the front. What is a good looking tire size to get for these that will fit on my car?
Old 03-04-2014, 04:29 PM
I would seriously consider using some BFGoodrich radial T/A's possibly some 70 series tires... That would set your Monte off in Great style IMO!
Old 03-04-2014, 04:42 PM
275/60/15s look good on 8" rims, id do 225/60/15s on the front
Old 03-04-2014, 05:23 PM
my v8 s10 has the same size wheels with 215/70/15 front and 235/70/15 rear. they are firestone firehawks. i was gona get the bfg's but at the time the 235/70/15 size was on backorder.
Old 03-04-2014, 05:33 PM
I did consider saying to use 60 series as well ... However in the 70's..70 series tires were what most EV1 used.... The 60 series looked best with 9 and 10 inch rims.. I think if he used them (60 series) on the smaller size 7 and 8 inch rims they would look more like a wide oval tire that has a flat. IMO...
Especially on a 2nd Generation Monte Carlo....
I'm not to sure a 60 series tire would even fit in the wheel well with out tearing up the side walls on the inner lip of the fender well.
Old 03-04-2014, 06:55 PM
Thats what i ran on my 86 cutlass with the same size crager ss wheels
Old 03-04-2014, 07:45 PM
That only also worked because the 1986 olds cutlass came with factory flared wheel wells..
However the 1973 Monte Carlo didn't...
2 totally different body styles...
Old 03-05-2014, 07:29 AM
03SSLE's Avatar
If you're going after the 'retro' look of a larger tire in back and a slight rake in the stance 215/70R15 up front would be the same as the old F70-15 tires. The 235/60R15 would replace the old G60-15.
Old 03-05-2014, 09:02 AM
Ok thanks for all the quick responses! Yes im going for the retro look, and would like a little rake. So 70 series it is. So your saying a 215 70 R15 for the front, and a 235 70 R15 on the rear, right? Also I really would like those bf goodwrench radials but man they arent cheap. I looked for other white letter tires couldn't really find any.
Old 03-05-2014, 11:52 AM
That's correct for tire sizes
Quick Reply: 2nd Gen ('73-'77): Finally got some rims for my monte, what is a good tire size that will fit?
