Drive Axle Question >?
Old Aug 21, 2013 | 09:05 AM
JC Colon's Avatar
Question Drive Axle Question >?
Hi Guy,
Are the drive axles on the Impala the same as the 00-05 Monte SS?
Old Aug 21, 2013 | 09:23 AM
Originally Posted by JC Colon`
Hi Guy,
Hi J.C., I don't know , but maybe the below link might help you until one of our expert tech's replies to your question. Good Luck
2005 CHEVROLET MONTE CARLO Parts - GM Parts - Genuine Replacement GM Parts - New GM Parts
Old Aug 21, 2013 | 11:36 AM
JC Colon's Avatar
Hay Space
I'm finding the gear ratio, 3.27 in the 3800 motor, makes a difference in the axle. I still don't an answer, But I'm getting closer!
Old Aug 21, 2013 | 12:25 PM
I am pretty certain the '00-'05 Monte and Impala use the same axle shafts.
I believe the only difference comes into play if you are dealing with a car that has a HD trans (found on the SuperCharged 3800). One axel shaft is shorter on the HD trans because it has to account for the bigger differential.
Old Aug 21, 2013 | 01:56 PM
JC Colon's Avatar
Thanks J, the sellers on EBay were not Very specific.
Old Aug 22, 2013 | 08:09 AM
03SSLE's Avatar
The aftermarket shows the same axle fitting the Monte and Impala. They do offer 2 options though - one has a 33mm axle nut and one has a 34mm axle nut. As long as the axle you're looking at has the same size nut as your original it should bolt right in.
MonteDriver
FWD Tech Guides '95-'07
16
Sep 29, 2019 01:30 PM
Dam20735
Apr 21, 2013 08:51 AM
mmonh
Jun 25, 2011 10:05 AM
MonteDriver
Mar 10, 2010 07:15 PM
