CV axle problem?? help!
Old Jun 6, 2012 | 06:47 PM
kingreyna's Avatar
Default CV axle problem?? help!
I've been having this vibration problem the past two months that's getting worse little by little. It has 81K and at about 75K miles I have replaced all struts, end links, both tie rods and the front drivers side hub with new tires.
The problem is that at 30 to 65 mph I have a vibration coming from the drivers side. My steering wheel doesn't shake at all. It feels like I'm driving down a bumpy road even on newly paved roads. I've had the wheels balanced twice and rotated.
Could this be a bad cv axle? The boot looks good, nothing is torn. I have read some members have replaced their cv axles and fixed their vibration problem? I just don't want to go replacing things that might not do anything to fix this.
Any help??
Old Jun 6, 2012 | 09:12 PM
CV joint seems like an odd item to cause that. I'd suspect a bad strut or coil spring. I have heard of new struts bad out of box.... Could be a wheel out of balance or a bad alignment....
I just don't see a CV joint causing a "bumpy" feel. OH!! Another thing to check, look at your control arm bushings (there should be a vertical and a horizontal one where the control arm bolts to the sub-frame). The vertical one may have worn or popped out of the control arm. That can cause all kinds of whacky road feelings.
Old Jun 7, 2012 | 08:32 PM
kingreyna's Avatar
Thanks. I'll look into all these suggestions. I just feel frustrated that I cant figure it out.
Old Jun 7, 2012 | 09:07 PM
I'm willing to bet when you find it, you'll have a "ah ha" moment and wonder why you did not see it before....
Best of luck, I hope you can find it and it's quick/easy to get done.
Old Jun 8, 2012 | 11:22 AM
you have any pulseing in the brake pedal when stopping?
Possibly a warped rotor... or froze caliper....(dragging)
But im leaning toward a broken axle.....
or even motor or trans mounts....
without actually being there its a little tough for me to figure out..
These are just suggestions to checkout...
racerjim0
Nov 10, 2014 06:47 AM
kcmarkviii
Oct 7, 2013 08:44 PM
Rhodes9702
Apr 19, 2010 08:04 PM
reswob
May 20, 2006 02:53 PM
01whitess
Oct 7, 2005 08:22 PM
