check your wheel weights
Perhaps the best way to begin is to discuss the lack of balance. When a tire is mounted onto the wheel, two slightly imperfect units are joined to form an assembly weighing forty pounds (this is the average for cars). The chance of this assembly having absolutely precise weight distribution about its radial and lateral centers is virtually impossible. Remember that all it takes is half an ounce of uneven weight distribution for a vibration to be felt.
The static imbalance creates a hop or vertical vibration. The dynamic imbalance creates a side-to-side or wobbling vibration. Most assemblies have both types of imbalance, and require dynamic balancing (commonly referred to as spin balancing) to create even weight distribution. The balancing system directs a technician to place counter weights on the rim's outer surface to offset the imbalance. When the balancing system tests for virtually perfect weight distribution, the assembly is in balance and will not vibrate. Your tires will ride smoothly and wear evenly with regard to balance.
I had lots of trouble with sticky wheel weights until I figured it out. They would fall off when washing wheels. Not all sticky weights are created equal. Insist on 3M sticky weights - find a place that uses them. They are much more expensive, which is why most places don't use them.
glad i could help dominic! that's why i posted this thread so other MCF members wouldn't have the same bad luck i did. from now on i'm going to make it a habit to check my weights frequently.
SpinEm_90
06-23-2010 06:33 PM
