Brakemotive Brakes
Just received front/rear pads & rotors from brakemotive and just have a real newbie question about the rotors...how do I know which are the front and which are the rears
Anyone have any tips for install? Or pretty straight forward job? Will be switching them out in the a.m
Brakemotive is an eBay brand that sells slotted/drilled rotors that I've heard pretty good reviews on. Couple guys on here have had them and say they are a good buy so I went ahead and picked up front and rears for about 170
Ok SOG, I may have spoke out of my *** there! looking at rock auto, the slotted and drilled rotor sets, (hi-perf), do seem to me front /rear, left/right specific? they also seem a different thickness front to rear where the bolt holes/hub area is? but the big thing I see is the direction of the slots seem to be left or right oriented! surely the manufacturer has provided some instruction of some sort I hope? im not sure which direction the slots should be curved to as in diver4s side or passenger side! sorry to jump the gun like I knew what I was talking about!!!
again I have visited the site for brakemotive! impressive stuff and affordable!! I see you can get four slotted/drilled roters AND ceramic brake pads for your 2007 for 167$?? I hope that's the deal you got???
Just compare the rotors you have now to what you are putting on. Normally the hat/hub/center of the rotors is different between front and back (it will be deeper on the back for the e-brake). Plus. the back normally does not have the center cooling fins that the fronts have.
Here's a few pics of brakemotive's drilled/slotted rotors. They look great. Have driven with them about 50 miles so far and honestly not a huge difference from OEM. For the price, I'd recommend and buy again in the future!
Cheap and drilled rotors shouldnt be used together. Multiple 5th gens found that out the hard way with the eBay R1 rotors they used to sell back in the day that would crack around the holes if you actually pushed them.
IMO OEM or equivalent blank rotors are where it's at for a street car. Better braking performance can be had with higher friction pads (at the expense of more noise and more dust) and with larger diameter rotors (for more mass / heat capacity).
