Bleed Brakes 2004 ss
Old Apr 12, 2007 | 01:06 PM
jasper's Avatar
Default Bleed Brakes 2004 ss
My brakes feel spongy, anyone bleed off their brakes, if so how?
Old Apr 12, 2007 | 02:31 PM
Mrrench's Avatar
Default RE: Bleed Brakes 2004 ss
first off bleeding might not take care of the problem
Check for leaks around the master cylinders, hoses and calipers,
Check the pads to see if they aregetting close to needing replacing.
If all that is ok
Get a friend have him/her pump the brake pedal, while they hold it down, open the bleeder valve on the caliper. ONce the pedal goes all the way down, close the valve before they release the brake pedal. Start with the right rear wheel, then left rear, then right front finish with the left front.
Check the brake fluid so that you dont run it dry while bleeding the brakes.
Old Apr 13, 2007 | 11:09 AM
jasper's Avatar
I give it a go
thanks
Old Apr 14, 2007 | 10:01 PM
mickey's Avatar
check for leakes and start with the farthest away from the master for the bleeding. then work to the next farthest etc....
Mueller
Jun 13, 2014 10:40 AM
John 952
Aug 4, 2013 02:42 PM
The_Maniac
May 7, 2013 06:34 AM
Jun 29, 2012 10:51 AM
05SSMonteCarloSC
Sep 17, 2009 12:34 PM
