Big Problem
Old 11-24-2008, 11:56 AM
mavrickf1613's Avatar
Monte Of The Month -- January 2009
Default Big Problem
I havetwo black brace bars on each side of my car underneath my hood and one is over the intake.
The brace bars are bending and they arn'tstraight anymore?
any reson why or has this happen to anybody?
also my transmissionis making a winding noise and I don't know why its making this noise. It only happens when you accelerate on the gas.
any feedback greatly appreciated.
I think I am gonna replace the brace bar'ssoon anda little later add a sway bar, or something
Old 11-24-2008, 01:19 PM
Default RE: Big Problem
in which ways are they bending????? thats odd and about ur trans you could have some kinda slipping going on. and id check your fluids for it.
if your under warranty you should be able to get both fixed easily
Old 11-24-2008, 03:30 PM
the bars are collapsing in and the medal is starting to stick outwars, the bars are 50 bucks for both to replace which I will do, but I don't want to keep replacing these if the problem may be a little bigger, My car isn't under warranty anymore, the warrant on mine was 3 year 36,000 miles, I have about 50,000 on my car now. I have a repair shop close to me that I trust and maybe I will get a $40 diagnostic check on the car.
Old 11-24-2008, 04:20 PM
Some where your twisting hard cornering? I would check your trans fluid, It maybe low? I would why your at it I would replace the trans fluid and filter too.
Old 11-24-2008, 04:51 PM
thanks guys, I do think your right bubba, I think 50,000 miles is reasonable time for a trans flush service, whats the usual milage for trans services?
Old 11-24-2008, 06:15 PM
ORIGINAL: mavrickf1613
I want to say every year? maybe someone will know the right miles
Old 11-24-2008, 09:58 PM
well I showed my brace bars to a friend and he says it doesn't look bent, its like collapsed in areas I gues so things can fit under the braces or so the hood can close, it looks bent a little but he said not to worry, but I definately think I need a trans flush. will do soon I need an oil change to.
Old 11-24-2008, 10:18 PM
can you get a pic of them??
Old 11-25-2008, 02:20 PM
Oh and I would put some redline atx trans fluid in there
Old 11-25-2008, 06:09 PM
Usually flush and replace tranny fluid every 30K miles.
Quick Reply: Big Problem
