7th gen MC stock/2010 Camaro SS wheel swap
Old Nov 18, 2011 | 03:12 PM
Vanaman's Avatar
Default 7th gen MC stock/2010 Camaro SS wheel swap
Hey everyone, I'm new to the forum and was just wondering if anyone had info on swapping out my stock 06 MC SS wheels with the new Camaro SS wheels. I know that the Camaro has an overall bigger wheel, but I wanted to know if anyone has attempted this or knew enough about the subject to tell me if it's possible with little or no mods, or completely ridiculous. Thanks a lot for your help!
Old Nov 18, 2011 | 03:13 PM
Not possible. They use a completely different bolt pattern.
Old Nov 18, 2011 | 04:02 PM
You can put mustang rims on it
Old Nov 18, 2011 | 05:13 PM
xxtheshockerxx's Avatar
RED DEVIL
the new camaro rims are would look great if possible. i wanted to get a set until i found out they wouldnt work
Old Nov 18, 2011 | 05:43 PM
You can find a list here of what will fit. https://montecarloforum.com/forum/ti...pattern-18015/
Old Nov 18, 2011 | 05:51 PM
Jester_20's Avatar
not to mention the front's and rears are different sizes . .
front 18's and rear 19's if i'm not mistaken
Old Nov 20, 2011 | 11:21 AM
Vanaman's Avatar
Thanks for all your help! This is my first Monte and I wasn't sure if the bolt pattern was consistent in newer Chevy models. I also had no idea that mustang rims would fit. Thanks a lot!
Old Nov 20, 2011 | 12:40 PM
definitely possible if you do rim adapters
Old Nov 21, 2011 | 02:25 PM
Vanaman's Avatar
How much would it cost to adapt my hubs and and how much work would it be? Also of I did this, do you know if the wheel wells would fit the Camargo wheels? I know they're a bit higher over all. Thanks a lot!
Old Nov 21, 2011 | 02:39 PM
As long as the tire height goes down while the rim size goes up you can keep the same overall diameter and your speedo and everything will work right.
I wouldn't adapt your lugs for this. Just try to find a PROPER Rim that will fit what you have. 5x115 is our bolt pattern. Look on various websites for a nice rim.
