7th gen MC stock/2010 Camaro SS wheel swap
Old Nov 22, 2011 | 07:35 PM
Vanaman's Avatar
Ok, thanks. I really enjoy learning more about my car. You guys have been a huge help!
Old Nov 22, 2011 | 08:02 PM
As long as the tire height goes down while the rim size goes up you can keep the same overall diameter and your speedo and everything will work right.
I wouldn't adapt your lugs for this. Just try to find a PROPER Rim that will fit what you have. 5x115 is our bolt pattern. Look on various websites for a nice rim.
Why not? Using an adapter makes a rim fit just like it were the proper bolt pattern, just get a thin one so added pressure is limited.
Old Nov 22, 2011 | 08:36 PM
Because you are adding a pointless additional possible failure point to one of the most important parts of a car.
They are nice rims, you CAN find aftermarket rims that will fit properly and look good.
Old Nov 22, 2011 | 09:09 PM
monte07's Avatar
X2 I AGREE RIM AND TIRE ARE THE THINGS THAT TUTCH THE GROUND AND IS THER MOST OR THE BIGGEST THING YOU DONT WANT TO RISK LIKE WE CAN WITH A ENGIN OR STEREO. sorry for caps rims tires breaks suspention should not be moded like that. lower springs yes better shocks yes great looking rims yes. but dont mess with some thing that puts jepordy to life around us and to us life is short dont risk it and just have fun. sorry if it sounded mean i appolojise
Old Nov 22, 2011 | 09:12 PM
monte07's Avatar
what i mean lower springs look good as well as a good pair of shocks will make it ride better. same as a set of rims that has the same bolt pattern that looks great to you dont risk it if you have to make a special plate to put on rims
Old Nov 22, 2011 | 09:41 PM
that's why you buy ones that aren't cheap and you'll be fine
Old Nov 23, 2011 | 11:01 PM
Mr.Monte's Avatar
someone should photoshop this. id like to see it!
Old Nov 24, 2011 | 01:23 AM
Enzo354's Avatar
STILL SLOW
I don't really see the issue with running adapters either, but to each their own.
Old Nov 24, 2011 | 02:33 PM
03SSLE's Avatar
Even if adaptors were used, I think between the thickness of the adapter and the difference in wheel offset (fwd vs rwd) the wheels/tires would stick too far out of the fenderwells.
Old Nov 24, 2011 | 09:36 PM
All Star's Avatar
Rolling with 20s on a Monte?
To each his own...I'm curious to see pics if it is ever done though.
