2002 Bolt Pattern Question
Old Oct 16, 2015 | 07:28 PM
Nick Sorensen's Avatar
Default 2002 Bolt Pattern Question
Ive seen that people say 115. I got a set Im interested in buying the guy says there 4 1/2 inch will that fit?
Old Oct 16, 2015 | 07:32 PM
Budsjlm's Avatar
4.5 is 114.3 you risk damaging the studs but with that said there has been a stupid number of W body cars running it that way for years without issue,
Old Oct 16, 2015 | 07:41 PM
there 20" verde rims.
what a w body?
Old Oct 16, 2015 | 09:05 PM
what a w body?[/QUOTE]
Our 6th / 7th gen Monte Carlo's (2000-2007) are classed as a W-body car, believe it stands for "Wide Body".
Old Oct 16, 2015 | 10:24 PM
GM used the W platform (W-body) chassis for a lot of FWD cars from 90's to present. Montes, Impalas, Regals, Grand Prixs....
This link might help:
https://en.wikipedia.org/wiki/GM_W_platform
Old Oct 17, 2015 | 07:20 AM
So I got a 50/50 chance of those rims fitting?
Old Oct 19, 2015 | 09:20 AM
Find out what car they came off of. There's a good chance that if they are from a RWD vehicle the offsets will be bad and the tire won't fit well.
Old Oct 19, 2015 | 10:14 AM
jsbihn's Avatar
will the 06 have the same bolt pattern?
Old Oct 19, 2015 | 10:17 AM
The 06 does have the same bolt pattern, however the SS variant has a different suspension set up allowing the use of taller tires. So if you want an SS rim on your car, you have to run a 245/45/18 instead of the 235/50/18 that came stock.
Old Oct 19, 2015 | 10:41 AM
jsbihn's Avatar
thanks
