2002 Bolt Pattern Question
Ive seen that people say 115. I got a set Im interested in buying the guy says there 4 1/2 inch will that fit?
4.5 is 114.3 you risk damaging the studs but with that said there has been a stupid number of W body cars running it that way for years without issue,
what a w body?[/QUOTE]
Our 6th / 7th gen Monte Carlo's (2000-2007) are classed as a W-body car, believe it stands for "Wide Body". |
GM used the W platform (W-body) chassis for a lot of FWD cars from 90's to present. Montes, Impalas, Regals, Grand Prixs....
This link might help: https://en.wikipedia.org/wiki/GM_W_platform |
So I got a 50/50 chance of those rims fitting?
Find out what car they came off of. There's a good chance that if they are from a RWD vehicle the offsets will be bad and the tire won't fit well.
will the 06 have the same bolt pattern?
The 06 does have the same bolt pattern, however the SS variant has a different suspension set up allowing the use of taller tires. So if you want an SS rim on your car, you have to run a 245/45/18 instead of the 235/50/18 that came stock.
thanks |
