05 monte 22 wheels
Old May 24, 2016 | 10:14 PM
Lj69's Avatar
Talking 05 monte 22 wheels
Anyone have 22 wheels on montecarlo? Trying to install set.seems they wanna hit strut above tire....
Old May 24, 2016 | 10:51 PM
Lj69's Avatar
Default 05 monte
Installed 22 wheels tires.rear wants to rub bottom of strut.any ideas????
Old May 24, 2016 | 11:36 PM
SkippyThorson's Avatar
I think you should post this same question in more places.
Old May 25, 2016 | 12:57 PM
Rubs on thr cylindrical part of the strut or the lower spring perch?
The easy solution is to get the tire spaced out away from the strut, either with a spacer or different offset wheel. Obviously it depends how much room you have before your tire hits the fender. If it gets too far out, you can roll the fender or get narrower tires out back.
If it's hitting the spring perch, you could go with coilovers to save a little space, but it depends how bad it's hitting.
Old May 25, 2016 | 07:12 PM
shawn parker's Avatar
pictures ?
Old May 25, 2016 | 08:40 PM
turbo monte's Avatar
I'm with this guy. one post is enough dude, no need to make duplicate posts about the same issue!
Old May 25, 2016 | 10:49 PM
Scott_S's Avatar
I think you'd get more answers in the Tires/Rims/Suspension section...
Old May 25, 2016 | 11:16 PM
I deleted the one thread with no replies and I merged the two threads that had replies and moved it to the correct section.
@LJ69 - No need to spam the forum with multiple posts on the same question. Please keep to one thread. Thanks!
