02 monte ss sway bar identification anyone
Old Oct 19, 2009 | 05:39 PM
Krobar's Avatar
Post 02 monte ss sway bar identification anyone
ok here we go I am currently trying to upgrade my suspension on my 02 monte ss. as far as i know I have the sport suspension which came standard with all ss for 02. my question is what size is the actual sway bar? for 02 ss I think its 32mm? I looked inside my rear decklid and i found RPO FE3 also and if this is true i want to get the GMPP 34 mm upgrade kit with the 19mm rear and tubular trailing arms. I tried identifying the actual part number for the sway bar thats on there now it is 25861193 and the 34mm GMPP number is 12498642. anyone? just trying to confirm what I need.
Old Oct 20, 2009 | 09:05 PM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Im not sure about the sway bars, but I was going to upgrade also to the 34 mm on my 00'. I already have the trailing arms on and let me say that they are def worth the up grade! You will tell the difference and laugh at GM for putting the U shaped stamped ones on in the first place! Hope this kinda helps!
Old Oct 20, 2009 | 10:36 PM
Krobar's Avatar
Post
Thank you for your input. I found a master rpo code sheet from GM that covers what i believe all monte carlo years. I do indeed have the sport suspension FE3 but my thing is I cant quite determine the actual sway bar sizes hat came on the sport fe3 package. I even have a machinist set of calipers and measured myself but the bar is shaped in a way thats hard to get a acurate reading but from what I can determine its 32mm.
Old Oct 26, 2009 | 05:38 PM
Wilco's Avatar
I was looking around and found this
http://cgi.ebay.com/ebaymotors/98-06...item45edaa701b
Rear Anti Sway Bar
.875" Diameter Solid Bar
I'm also thinking about replacing it but I'm not sure what to get.
Old Nov 2, 2009 | 10:52 PM
montes my python's Avatar
I've got what you want for your monte, see my post at
https://montecarloforum.com/forum/sh...ad.php?t=16637
l67ss
Nov 29, 2013 07:48 PM
MONTE2000SS
Mar 8, 2012 08:05 AM
1996Monte_Carlo
Jan 14, 2012 06:41 PM
04 Intimidator
May 8, 2007 09:21 PM
laredoggg
Nov 16, 2006 04:47 AM
