02 monte rear wheel bearing assembly issue
Old Sep 28, 2009 | 02:49 PM
valvefloatss's Avatar
Default 02 monte rear wheel bearing assembly issue
I’m new to the forum. I have done some searching and haven’t found any help yet. I have a 02 monte ls. The rear wheel bearing went bad on it. The speed sensor gave me troubles. I changed it. I removed the spindle assembly. Pressed out the bearing assembly then put it all back together. The car had a shimmy to it. I drove it that way for 2 years. Put another bearing assembly on it. Figured I had a bad manufactured assembly. Still have a shimmy to the cars ride. Any thoughts to why it shimmys?
Old Sep 28, 2009 | 04:59 PM
Budsjlm's Avatar
what speed was it at? when was the last time the strurs where replaced?
Old Sep 28, 2009 | 08:38 PM
she has 82k miles on her. never had struts replaced. seems low mileage to consider. problem did not exist until I changed the hub assembly. I feel the shimmy around 50 mph.
Old Sep 30, 2009 | 08:15 PM
RocknSS04's Avatar
Sounds like a bad tire to me. Might just need balancing. Another thing it could be, how did you torque the lug nuts? By hand with a torque wrench set to 100 lbs, right? These cars are REAL sensative to mis-mounted wheels. I've had several brake rotors messed up from that.
My 1st guess is a bad tire or a wheel out of balance.
Old Oct 2, 2009 | 06:15 AM
thanks. I have considered swapping the wheel with a front. Been to miserably cold and wet!
Bkm1981
Aug 18, 2015 08:26 PM
05_monte
Apr 3, 2013 04:51 PM
thumpingetocar06
Feb 1, 2011 12:17 PM
uptownfam
Nov 23, 2010 05:04 PM
teamfbody
Apr 12, 2010 10:18 PM
