RWD Tech Guides '70-'88 Guides/How-To information for RWD Montes 1970-1988
Repair Guide: Multiplex Wiper System
Old Jun 30, 2010 | 11:06 PM
Montecarloconvertible's Avatar
Default Multiplex Wiper System
WIPERS INOPERATIVE
Turn ignition on and check for battery voltage at wiper motor terminal 2, Fig. 5, using a test lamp.
If lamp fails to light, proceed as follows:
Check wiper system fuse and replace if needed.
If fuse blows again, disconnect electrical connector to motor and replace fuse.
If fuse does not blow with harness disconnected, replace wiper motor.
If fuses continue to blow with harness disconnected, or if fuse was satisfactory in step ``a,'' repair feed circuit to wiper motor.
If lamp lights in step 1, check for battery voltage at motor terminal 1.
If lamp fails to light, check terminal board connections and repair as needed. If connections are satisfactory, motor is defective.
Place wiper switch in low position, disconnect electrical connector to gear box relay and connect test lamp between terminals 1 and 2 in connector.
If lamp fails to light, check continuity of wiring between motor and switch, switch continuity and ground, and repair as needed.
If lamp lights in step 5, place wiper switch in high position, disconnect electrical connector to pulse timer and connect test lamp between terminal 6 and timer connector and terminal 2 in gearbox relay connector.
If lamp fails to light, check continuity of wiring between motor and switch, switch continuity, and repair as needed.
If lamp lights in step 7, motor is defective.
WIPERS WILL NOT SHUT OFF
Crank Arm Rotates 360°
Operate wipers with switch in delay position.
If wipers operate properly in delay position, proceed as follows:
Place wiper switch in off position, disconnect electrical connector to gearbox relay, and connect test lamp between terminals 1 and 2 in connector, Fig. 5.
If lamp lights, check for grounded wire between motor and switch or defective switch, and repair as needed.
If lamp does not light, remove washer pump and inspect gearbox relay latch arm spring, Fig. 15. If spring is properly installed, motor is defective.
If wipers do not operate properly in delay position, motor is defective.
Wipers Cycle In & Out Of Park Position
If wipers operate properly at low speed, motor is defective.
If motor does not operate properly at low speed, refer to ``Motor Operates At High Speed Only
Fig. 5 Multiplex pulse windshield wiper motor
MOTOR OPERATES AT HIGH SPEED ONLY
Ensure electrical connector to gear box relay is secure, turn ignition on, and place wiper switch in low position.
Connect jumper wire between terminal 3 on gearbox relay, Fig. 5, and ground, leaving harness connected.
If motor operates properly at low speed, check continuity between wiper motor and switch, switch continuity and ground, and repair as needed.
If motor does not operate at low speed with terminal 3 grounded, motor is defective.
MOTOR OPERATES AT LOW SPEED ONLY (OPERATES PROPERLY IN DELAY & PARKS PROPERLY)
With ignition on and wiper switch in high position, disconnect electrical connector to gearbox relay, Fig. 5, and connect test lamp between terminals 2 and 3 in connector.
If lamp lights, motor is defective.
MOTOR INOPERATIVE IN DELAY MODE
Place wiper switch in mid-delay position and disconnect electrical connector to pulse timer at wiper motor.
Connect ohmmeter between pulse timer terminal on motor and ground.
If meter indicates continuity, motor is defective. If meter indicates no continuity, replace wiper switch.
WIPERS RUN CONTINUOUSLY IN DELAY MODE
Operate wipers in all switch positions. If motor fails to operate at low or high speeds, or if wipers do not park properly, correct these problems before proceeding.
With ignition on, place wiper switch in mid delay position and disconnect electrical connector from pulse timer at wiper motor, Fig. 5.
If wipers stop, check for grounded wire between pulse timer and wiper switch. If wiring is satisfactory, replace wiper switch.
If wipers do not stop when timer is disconnected, motor is defective.
INTERMITTENT OPERATION--BLADES STOP RANDOMLY DURING OPERATION
Remove wiper system fuse and connect ammeter across fuse terminals.
Operate wipers at low speed while observing current draw on meter. Readings will fluctuate.
If lowest reading is 5---6.5 amps, motor is defective.
If lowest reading exceeds 6.5 amps, replace wiper blades and repeat test.
If lowest reading still exceeds 6.5 amps, disconnect linkage from motor and repeat test.
If current draw is less than 6.5 amps, repair binding linkage. If current draw exceeds 6.5 amps, motor is defective.
Old Jul 8, 2010 | 04:43 AM
osantisbon's Avatar
Excellent information. I will go far, because my windshield wiper switch has a generic, for wich only has one speed.
Sorry for my english.
This inrmatión is the? Haynes manual or Chilton. I know a site where all the service and maintenance manual of the chevy Monte Carlo of the every years.
Thanks
Old Mar 16, 2014 | 07:47 PM
oblada's Avatar
70 Monte Carlo, needs new switch, any way of doing this without removing the whole dash? I have attempted feeling my way, It seems the plate below is separate, but the underneath access, seems like smooth, instead of screws..
Old Mar 16, 2014 | 09:39 PM
Shelbo Mustang's Avatar
Nice info. I'm sure a lot of people will be using it!
Old Apr 4, 2017 | 08:43 PM
Perdue18's Avatar
I know this doesn't pertain to this topic but I recently purchased a project Monte Carlo 1979. The steering column is locked so I'm unable to turn the wheel and shift the car into neutral to load it onto the trailer. The reason the column is locked is because there is no keys for the car the previous owner lost them or never had them. Is there anyway to remove that safety "column lock" or anyway to unlock it with out having the key so I can get it on my trailer?
jims875
Feb 5, 2008 07:32 PM
Endo
Jan 12, 2008 12:55 PM
bob pal
Dec 14, 2007 03:24 PM
scc24540
Aug 20, 2007 07:26 PM
