PRIVATE Wanted Classifieds Looking for something? Tell us!
Wanted: Supercharged engine harness
Old Sep 5, 2012 | 12:44 AM
Dam20735's Avatar
Default Supercharged engine harness
Does anybody have one for sale i did a whole top swap but I know this what I need to an the one I had is bad so anybody have oneet me know ASAP
Old Sep 5, 2012 | 06:12 AM
LW57912's Avatar
You probably don't need the whole harness. ZZP sells a L67 swap kit so you can buy that and it will give you a L67 MAP harness you can splice in and a BBV harness assuming you want to use the BBV through the computer. You'll get more boost if you don't connect it and let it operate through vacuum. So really all you need is the MAP harness.
You may need injector connectors as well. I think if you had a 2001+ you will need these. Other than that all of your original harness should work.
However if you want to replace the whole harness its probably easier to get the L67 harness and in that case check Morad Parts as they usually have them.
Old Sep 5, 2012 | 08:17 AM
Dam20735's Avatar
Ok idk it's a sensor In the back of the supercharger idk what plugs into that an I know everything matching I just dont wanna go threw slicing them running into any problems
Old Sep 5, 2012 | 09:19 AM
Take a picture, there is a harness on the engine that hooks up to a CA emissions air pump
So if you just have a connector sitting in the engine bay not plugged into something, it could be nothing.
Old Sep 5, 2012 | 06:24 PM
Enzo354's Avatar
STILL SLOW
That's probably your map, you need an extension to run back from where it was before.
Old Sep 6, 2012 | 07:59 AM
Dam20735's Avatar
Ok it's the map sensor does anyone have a layout diagram or anything show what goes where an etc
Old Sep 6, 2012 | 08:10 AM
Old Sep 6, 2012 | 05:59 PM
Enzo354's Avatar
STILL SLOW
Also, only wiring harness compatible is the 04-05 monte carlo supercharged harness. Still not worth doing.
Old Sep 22, 2012 | 10:07 AM
Dam20735's Avatar
Anybody have one?????
Denarius23
Sep 17, 2014 02:18 AM
Dam20735
Dec 1, 2012 08:35 AM
Dam20735
Sep 22, 2012 01:22 PM
blackbeauty89
Nov 22, 2011 06:21 AM
gotit4cheap16
Jul 29, 2010 08:12 AM
