Wanted: L36 Passenger Side Engine Bracket
My bracket got a hairline crack in it, I'd like one for the same price zzperformance had them.
GM ACDelco - Used L36 Engine Passenger Side Bracket #ZZ-USED-L36PSBRKT
When mine broke I upgraded to the cast iron mount / coil pack mount found on GTPs and most L67s I believe? A good upgrade that you definitely won't break. Also just a good idea if you plan to mod your Monte
If you contact ZZP they may have a few of those that they'd sell for the same price as the aluminum mount.
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
I highly recommended the cast iron bracket as well. It will never break and they sale for around $35. Your icm and coil packs will swap right over on it no problem.
01 monte ss if I remember correct wasn't I the 1 that told you about doing this? Glad to see you are!
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
it looks nothing like it but it will most def work and is alot stronger.
you are talking about the aluminum mount on the passenger side beside the coil packs correct?
Trust me.. this is what you need. (it mounts to the side of the engine instead of on top like the little aluminum mount) If you replace with aluminum you risk over-tightening and just breaking it again. If you pick up a cast iron mount like I pictured above, you'll thank me later if you plan on modding or just want that extra security.
And, if Turbo Monte uses the cast iron mount and has no issues, you will most definitely be fine
And, if Turbo Monte uses the cast iron mount and has no issues, you will most definitely be fine![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
