Old Dec 22, 2023 | 07:13 PM
  #501
Monte SSV's Avatar
Default Last pix
Last set of 8 pix were frame pass through getting ready for fuel lines and wiring. More progress. slow but sure.
Old Sep 14, 2024 | 06:50 PM
  #502
Monte SSV's Avatar
Default Catch up
Well guys it looks as if it has been a long time since I was on the forum. Things have been moving along on SSVII but very slow for all kinds of reasons - just too many to get into - I guess I would call it moving along but at a very slow pace.
Well I am on my third tranny in SSV I (1 stock & 2 rebuilds) and decided it is time to change. If I can make that 4T65E-HD last as long as I did - I am going to try and make the the 4T80E work in my car. A 4T80E out of the box is good for 500HP From what I have researched and I understand there are some out there pushing 750 & 800 at the crank with some modifications. And I do believe I can make the 4T80E fit without moving things forward as is suggested by LS4 King- I will be using his mounts and modify them to make them work as a direct replacement that will not change engine location.
I figured now my 4T65E should stay together a bit longer with the new clutch pack of 5 in lieu of the 6 pack that is no longer available and increasing the clamping pressure - I should be able to make a 4T80E Last even longer with the types of modifications I can do to increase its' strength - and make it stay together with 800+ on the ground.
What destroyed the first rebuild was thrust washer failure primarily - due to excessive heat and no lubrication based on the factory design - so I increased the strength of the metal used from 1095 to 4340 added 6 EDM'd oil channels .005 deep in each washer both sides (not present in factory style washers, increased thickness from .030 to .040 and went from 2 to 3 washers in the diff where located. The diff had to be EDM'd to accommodate the taller stack of washers in each location of the diff.
And I am going to change my dash cluster in SSV I - I don't like what I have and am going to put all those gauges that are on top of the dash in the cluster - that way it will be completely stock in appearance and will give me a better view out the windshield. The cluster won't be stock but the dash will.
Well that is what is new guys - long time - sorry it took so long.
Now all I want to do is make the Monte Forum Club meeting at Metro park a few short miles from me on the 12th of. October..
Old Sep 15, 2024 | 06:51 AM
  #503
Good to hear things are moving along. Thanks for the update.
Old Feb 28, 2025 | 07:06 PM
  #504
Monte SSV's Avatar
Default Progress on my RWD
Well guys I have good news - things are moving along a bit faster - I am going to post a link here to Youtube showing my ice tank functioning outside the car - its something - the next video or pix with be the fuel tank set up with the 4 pumps inside. Anyway still a long way to go but here is today's update.
If this link doesn't work I AM sure you can go to YouTube and find it under. ICE TANK TEST. - IT IS NARRATED
Old Mar 20, 2025 | 10:56 AM
  #505
Thanks for the update Sam, and it was nice to finally meet you at the MMCC Fall Meet this past October!
Old Jun 25, 2025 | 05:28 PM
  #506
Monte SSV's Avatar
Default Great time at Octobers meet.
Matt the pleasure was all mine. I really enjoyed my time spent that day with everyone, something I was looking forward to for a long time.
Now to just get my other car (SSV II) done so I can attend another meet with something new to introduce to everyone!! Many thanks. Sam
elpanzon1
Apr 24, 2023 08:41 PM
ZIPPY02
Aug 2, 2022 07:01 AM
Jeffs02rwdSS
Jun 15, 2018 06:14 PM
jayheff
Nov 25, 2015 11:43 PM
red04montels
Apr 21, 2015 11:09 AM
