Rear spoiler swap.
Old Jan 13, 2013 | 01:52 AM
Tom02SS's Avatar
Question Rear spoiler swap.
Can anyone tell if it is any problem swapping out the rear spoiler on my 02 SS with the upswept Nascar style? I was wondering if the bolt holes were the same before I purchase one.
Old Feb 19, 2013 | 10:56 PM
michaelwells86's Avatar
the bolt holes are not the same. i just got mine in today. you will need to fill the old holes and drill new ones.
Old Feb 19, 2013 | 11:18 PM
The 06/07 will be the same, but the 00-05 is completely different. You will have to fill the holes and repaint unless you go a different route. Then you'll also have to drill new holes for the new spoiler.
You may want to look into a whole new trunk lid with that spoiler, if you're lucky i'm sure you can get one your color for around $100 at the yard
Old Feb 20, 2013 | 09:44 PM
I swapped the surf board spoiler on my '04 with an 06/07 vertical spoiler. Same bolt pattern, but it does not cover the same surface area (therefore you will need to get the spoiler painted and the trunk lid).
Old Feb 21, 2013 | 07:52 AM
I posted on a whole thread on this when I made my switch:
https://montecarloforum.com/forum/pa...er-faqs-31517/
^Click that link
Old Feb 21, 2013 | 07:54 AM
Shouldn't the trunk lid already have paint where the spoiler covers?
Actually the 06/07 spoiler conversion would look nice, as it does on Maniac's. If you decide on that, and it's possible to find one in your car's same color, then no painting should be necessary, just cleanup and such. The colors available between model years 00-05 and 06/07 changed a little bit so it depends on your car and what's available. The spoiler will probably be a hard one to find.
If you do go with an 00-05 standup spoiler I'd also recommend getting the whole trunk lid as well.
Old Feb 21, 2013 | 10:46 AM
It has a tendency to rub so it takes some paint off unfortunately.
Old Feb 21, 2013 | 11:04 AM
I have pictures showing that the surfboard extends JUST a touch beyond what the stand-up does, and how it wears at the paint.
Old Feb 21, 2013 | 11:48 AM
The surfboard covers more of the turnk then the 06/07 vertical spoiler. GM did not do much to account for "friction". In my case and Chibi's case, our surfboards rubbed away the paint where they rest on the trunk lid. When you put the new 06/07 vertical spoiler down, you then end with an issue of small exposed surfaces that are primer or bare metal due to the friction (Chibi has pics of the issue).
1984SuperSport
Jul 22, 2010 07:51 PM
2003montess
Feb 3, 2010 10:50 AM
jasonmcr
Jan 18, 2008 02:44 PM
Lee55
Jun 10, 2006 07:38 PM
ralphtrent
Aug 18, 2005 06:32 PM
