4th Gen ('81-'88): patch panel tips
Old Mar 25, 2014 | 12:56 PM
jenningsm5.7's Avatar
Default patch panel tips
I need to use a patch panel on my rear quater panel in front of and behind the tire and tips ??
Old Mar 25, 2014 | 03:48 PM
Be sure to cut out all of the rust about an inch either side of it...
o you have acess to a plasma cutter? if not I recommend a very sharp pair of tin snips... also be sure that when you button in the patch panels I would recommend 3 sided magnets to help hold it in place or some body panel clamps.. Also when your welding in the new patch panels be sure to tack weld it in in a criss cross pattern VS welding it from one end to the other... The whole idea is to not warp the new patch piece... by doing criss cross pattern of tacks ...that will eliminate any possibility of warpage...
Hope this helps...
I'm sure others will chime in with other helpful hints/ideas
Personally I have never done it myself...
Maybe checkout youtube for some helpful info as well..
bobj49f2
Nov 14, 2011 06:49 PM
jogasz28
Sep 4, 2009 07:40 PM
95monte
Aug 16, 2006 10:02 AM
montejass
FWD Tech Guides '95-'07
Jul 7, 2006 08:44 PM
snacks41
Mar 29, 2005 09:28 PM
