6th Gen ('00-'05): painting trim
Old Apr 12, 2013 | 05:57 AM
Murray137's Avatar
Default painting trim
I was looking at painting my bottom trim. Anyone have pics of what it would like like on a red Monte? I was looking at either, silver or black.
Old Apr 12, 2013 | 10:33 AM
sdowney's Avatar
I've seen red with silver trims and it gives it a pretty sweet look. But i think its more of a nascar look. I think the black looks better though. I've attached a couple pics that I found on google. Are you planning to take it somewhere to get painted or are you going to do it yourself? If your doing it your self, how? I've been looking into painting my trim black on my silver Monte but I'm not sure on how to do it. Can ya help me out?
Thanks!
Attached Thumbnails painting trim-silver-trim.jpg   painting trim-black-trim.jpg
Old Apr 12, 2013 | 11:53 AM
zzapultimate's Avatar
I vote black
Painting plastic trim pieces yourself is relatively easy. All you have to do is scuff the surface with scotchbrite or around 320 sandpaper, clean the surface, tape it off, then spray the paint and clear. Take the tape off and let it cure and then cut and buff
Old Apr 12, 2013 | 12:08 PM
Murray137's Avatar
I was looking at plasti dipping the trim. I dont have the high sport kit so I would be just painting the bottom trim but still not sure how it would look.
Old Apr 12, 2013 | 12:15 PM
Well the good thing about plasti-dip is if you don't like the way it looks you can peel it right off
Old Apr 12, 2013 | 06:59 PM
sdowney's Avatar
I vote black
I want to put a black trim on my silver Monte. When you sand, do you sand all the silver paint off? How do I know when to stop sanding? And, what kind of paint should I buy?
Old Apr 12, 2013 | 09:34 PM
Here's a few pics of a Monte without High Sport with the bottom trim painted.
Old Apr 12, 2013 | 09:48 PM
Red Nightmare's Avatar
Go with black! Red & black are perfect together
Plasti dip is easy to do, just get some painters tape!! & make sure when you pull the tape the edge is still wet.
Old Apr 12, 2013 | 11:22 PM
You don't have to sand all of the paint off, just enough to get rid of the shine of the clear coat. Basically you are getting rid of the smooth shiny surface of the paint and giving the new paint something to grip on to.
Any automotive spray paint will work. I like duplicolor personally as I have had good success with it. Be sure to clear coat it as well so it's protected and shiny.
Old Apr 13, 2013 | 08:08 AM
sdowney's Avatar
Awesome! Thanks a lot! 2-3 coats I would assume?
2000_BLACK_SS
Apr 7, 2012 02:51 AM
mairj40
Nov 10, 2011 03:14 PM
GoBucksBeatBlue
Jun 14, 2011 01:16 PM
z34_98blue
26
Aug 11, 2010 06:01 PM
wht02monte
Mar 11, 2010 09:50 PM
