Paint Code... I'm confused...
Old Apr 27, 2010 | 06:32 PM
racingdave's Avatar
Default Paint Code... I'm confused...
okay, i've searched the forums and know that the paint code for my '98 monte is located under the trunk lid. everything that i've read says that i'll see something that resembles a 4 digit code that will be the paint code after the "bc/cc". well here is the sticker from my car:
what is the paint code? it's not the 52D... is it?? i thought that the code would start with a 'U'.
thanks.
dave
Old Apr 27, 2010 | 07:10 PM
mrl390's Avatar
Hmm... Im not sure why your sticker doesnt have a code on it. I dont think the 52D is the code. It should be a code that looks like U####. For example, my car is torch red and the code is U9075.
Old Apr 27, 2010 | 08:10 PM
Wilco's Avatar
You may want to check this website out. It may have the color to your car although it doesn't tell the color code by number but by name.
http://www.vehix.com/used-cars/used-...8/monte-carlo/
Or it may be this one: Lt. Driftwood Metallic. 33U
Old Apr 27, 2010 | 08:30 PM
nascar43's Avatar
Default paint code
I'm thinking the same thing ? And they usually appear seperate
from the other codes. There are three other codes with a U in it
but that 33U looks like it. My 96 S10 has simular codes but they
are seperate from the list.
Old Apr 30, 2010 | 01:11 AM
06MONTECARLOLT's Avatar
If i was you the first thing I would do is call your local paint supplier and give them your year and make (sometimes your VIN too depending on your supplier) and then have them look up that 52D code, and they could mix you paint from there if its the right code. If not chances are they'd have a good idea of where to look to get the right code.
Old Apr 30, 2010 | 05:37 PM
Nuffy's Avatar
call any gm dealership in your city with the last 8 digits of your vin number.. they will give u your code in 2 mins.. unfortunatly, sometimes the code isn't printed, its happens to about 1 in 60 cars
the code will have be 4 digits or 3 and a letter i.e mine is 910L.. if you plan on mixing your own you'll have to add WA in front.. i.e wa910L
fevy
Aug 4, 2009 09:58 PM
MyIntimidator
Dec 20, 2007 09:01 PM
Monte
Nov 8, 2007 07:18 PM
mtwallet
May 3, 2007 01:22 AM
NYmedic2992
Mar 28, 2007 08:56 PM
