7th Gen ('06-'07): ok a question about led turn signals
Old 06-16-2017, 08:14 PM
monte07's Avatar
Default ok a question about led turn signals
with led turn signals don't a person have to install a resister inline of the power wire of the turn signal to make sure the timing of the light flash. the reason why I ask is the led tail lights I have put on and the front led turn signal bulb as well. I am wondering what do I need to make it slow a little than having it flash fast like I have a burned out bulb. also I do not want to **** of a state trooper either rather make them laugh than make them mad.
Old 07-09-2017, 06:15 PM
Haven't done my monte yet, but did my ranger full led and I used Sylvania LOADRSLBX2 - Load Equalizer | O'Reilly Auto Parts just hook them up to turn signal power and ground wires at light side and mount to "metal" not plastic as they get hot as the sun (not really but you get idea). Need at Least 2, one for each side.
Electronic flasher wouldn't hurt either.
Old 08-08-2017, 09:19 AM
Did my fronts earlier this year. You have to wire it parallel with the bulb. Just splice into the blinker power wire and the ground wire. If its wired in series, it will still blink fast.
Old 03-01-2019, 09:37 PM
monte07's Avatar
thanks guys I forgot to respond in a while thank you for your help
Old 03-01-2019, 09:41 PM
monte07's Avatar
now I have another question I put in the led tail lights and now I have the same thing again do I need to install the same thing again. or is it the lights?
Old 03-03-2019, 11:50 AM
On these cars resitores are needed front and back for turn signals but not brake lights (at least my 03 was that way)
Old 03-06-2019, 01:47 PM
monte07's Avatar
thanks I was not sure to be honest but they do look a lot better than the ones I had on because they started that cracking on the outer lenz but I do like the ones I had on as well they both look good. thank you for the input I wasn't sure to be honest. but on a weird not a officer thought they were completely smoked out till he looked and asked can I hit the brakes real quick I was ok. but he did say it looks a lot better than the ones I had on before. he usually came in my store now and then to get some things. he wanted to ask to let me know to becareful till he noticed that they were not total black. he said he didn't want me to get a ticket but when he seen it he dig it.
JohnieWalker305Blue
07-25-2013 07:49 AM
shad420w
04-07-2011 10:31 AM
Pure2sin
01-31-2011 07:48 AM
03BlueMonte
02-22-2010 05:48 PM
eroc74
12-20-2009 12:11 AM
Quick Reply: 7th Gen ('06-'07): ok a question about led turn signals
