need help with de-badging
Old Oct 25, 2010 | 02:06 PM
Boxman420's Avatar
i have not tried a clay bar yet or the thing blazed SS suggested. those will be by next attempts for sure though.
goth kid. i am a little worried using a razor near my car at any time let alone on it. i may try that i guess i could always get it touched up if i mess up.
trewyn. that might have been my problem. i did not let it settle on there i just put some on there and started rubbing and scraping so i will try letting it sit on there and see how that goes.
thanks for all the help so far. i will let everyone know what works
Old Oct 25, 2010 | 02:49 PM
Blazed SS's Avatar
IT HERTZ
I know mine will work just call a body shop and the should charge you like 10$ to do it and your paint and clear coat will be still intact
Old Oct 25, 2010 | 04:59 PM
Boxman420's Avatar
okay ill have to call some places tommarrow theres like 50 auto body shops in like 10 mile radius.. also this stuff thats on my car right now isnt black. i got all the black stuff off . all thats left on there is clear and hard
Old Oct 25, 2010 | 07:38 PM
Blazed SS's Avatar
IT HERTZ
Copy.
Old Oct 25, 2010 | 08:15 PM
bob442's Avatar
take a picture of it. use a paint thinner as in solvent soak it a few times with a rag, it should come off no problem. use a clean rag and keep whiping it with the soaked rag and turning the rag to clean spots so you dont scratch the paint! dont let the solvent go on the window trim as it may dry it out.
Old Oct 25, 2010 | 08:45 PM
Milhouse's Avatar
Originally Posted by Boxman420
So I went to take off the monte carlo emblem behind on the rear side windows and I took one off with string.. it came off fairly easy. I got all the rubber crap off and now im left with, what seems to be dry super glue. its hard and crusty and it looks like it bunched up at the bottom.. i just left it there for now. I dont think that is supposed to be there. i didnt take the other one off yet. because im just gonna put the emblem back on(without glue) if i cant figure out how to get it off. if some one could enlighten me on how to get this stuff off id appreciate it. if not ill just put it back on.
Do you have access to a heat gun? I'd heat it up for a bit and see if it gets tacky. If it does, soak a rag with goo gone and hold the rag over the area for a while then try to rub it off. Repeat as needed.
Old Oct 25, 2010 | 11:52 PM
Boxman420's Avatar
i can get some pictures tommarrow.
i have access to a hair dryer? if that counts? i will try that tommarrow. i got alot of things to try tommarrow hopfully one works
Old Oct 26, 2010 | 12:26 AM
Milhouse's Avatar
Good enough
Hopefully one of the suggestions works for ya, let us know how it goes
Old Oct 26, 2010 | 01:42 PM
Boxman420's Avatar
this morning i took a hair dryer and some goo-gone to my car and after many frustrating attempts at no success, i took my car out to a few shops and to autozone. and apparently the genius who owned the car before me, decided it would be a good idea to super glue that emblem on. it probably fell off some how and he super glued it back on. and from what they told me, u have to sand it off then repaint it. and that is not worth the hassle for just that little emblem.
Thank you everyone for ur help.
Old Oct 26, 2010 | 01:46 PM
i read that if you just let it soak in water also it will lose its form and fall apart.
could also try some gasoline
